Cutting holes in dash bezel?
Seems like the dash bezels would crack easily, would a hole saw be the preferred tool in cutting more gauge holes?Thanks.
Grandpa in the rustmobile...
Re: Cutting holes in dash bezel?
I cut some holes in my old bezel for guages, used a hole saw
all was well except 1 hole toward th edge alreayd had a small crack, it just made it worse ...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
if you can use a slower speed on the drill that will keep it from heating the plastic too much
I recently dried a hole for a factory manual choke cable under the wiper switch on my '71 Custom/30 tow truck using a paddle bit and it went just fine. A hole saw would be even better.
I wonder if the tip from the "This Old House" show a few weeks ago might help.
They needed to cut through aluminum siding to install a vent and one of the 'guru' used a hole saw... but had the drill running in REVERSE to minimize the chance of tear-out. |
That's a pretty good tip to play it safe,but certainly not necessary,especially here. .019-.024 aluminum siding is thin material and metal,which can bend if snagged. Cutting plastic is handled the same as wood in most cases. And,the teeth on a hole saw are identical to those on a circular saw plywood blade,which is what I used,frontwards,to cut thousands of squares of aluminum siding with no issues. People would turn a crosscut blade backwards to cut aluminum siding when all they had to do is use the right blade.
