11-27-2011, 03:31 PM | #1 |
Help with Final adjustments
I have had a reasonable difficult time adjusting my rockers. It seemed that every time I adjusted the rockers they would change. I came to find a large vacuum leak at the base of the carbourator, where the gasket goes. I changed the gasket and the engine runs well, what a diffferent.
I am now left with a rocker noise on load, that is when I give it gas. Is this good or do I need to further adjust my rockers. The sound is not loud but I some what feel to it should not be there. |
11-27-2011, 09:14 PM | #2 |
Resistance is Futile
Re: Help with Final adjustments
Is this a new or old motor? I just fired up my 454 after an extended period of sitting and it rattled for awhile until it warmed up.....now it's ok.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
11-27-2011, 10:13 PM | #3 |
Do you have screw in studs and is it a stock cam or larger lift? I have had larger cams actually unseat the press in studs and make adjustment impossible. You did use a zinc additive in your oil right?
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
11-27-2011, 10:50 PM | #4 |
This engine is a 292 and I installed a new cam new lifters and new orings on the valves. I used a beak in oil to start her up.
Like I mentioned in my first post I ad a problem dialing in the rockers, but soon discovered a major vacuum leak. After fixing the leak the engine sounds and runs well. The only problem is that when I driving and it the gas it sounds like I still have to adjust the valves. I hear a little valve chatter. |
11-27-2011, 10:56 PM | #5 |
Lifter clatter when accelerating under load...?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
11-27-2011, 10:58 PM | #6 |
11-27-2011, 11:02 PM | #7 |
I thinking you have some preiginition going on, timing is advanced to much, this will happen especially when driving up a hill in say third and not down shifting, check your timming and vaccum advance.
11-27-2011, 11:04 PM | #8 |
11-28-2011, 01:30 AM | #9 |
timing and todays poor grade of fuel will give you a clatter under a load. Set the timing and try a higher octane fuel or some fuel additive. How old is your fuel in the tank? if it has been sitting a few months while your engine build was going on it could have starting loosing its kick. Todays fuels aren't meant to be stored for very long.
We live in a fast paced world now where Autos get driven more in a day than they would in a week when our trucks were new. They don't plan on fuel sitting in tanks, plus all the good stuff is bad for the enviroment .... no more lead = no more valves
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
