Old 11-27-2011, 03:43 PM   #1
dtkarst
Trim questions
Where is the best place to get the white plastic clips that hold a piece of the door trim and the upper bed side trim? I dont think i can save mine anymore a few of them have broke with very little handling. And also what os the best way o polish up the trim on these trucks without taking it too far? ANy help would be appreciated. Thanks.
dtkarst is offline   Reply With Quote
Old 11-27-2011, 05:34 PM   #2
PGSigns
PGSigns's Avatar
Re: Trim questions
Any of the vendors that sell the trim also sell the clips in a set. The trim was anodized and still has that on it. So they are hard to polish with out removing the coating. There are methods for doing it at home available on the net. I took my cab trim to a local plater and they stripped them. I am almost done polishing them then they are going back to be anodized again.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-27-2011, 08:00 PM   #3
oem4me
Re: Trim questions
Like the sign guy says, you may shine the trim up a little with a coat of wax, but to really polish the metal you first must totally remove the anodizing. One can do it the hard way and sand it off with a fine abrasive. Others have reported using oven cleaner with some success. I bought some "anodizing remover" solution at a swap meet and it works quickly. Once the aluminum is bare, you can straighten it out and polish it like a mirror fairly easily. Wax will then help it stay bright, or have it re-anodized.
Old 11-28-2011, 10:25 AM   #4
1963c-10
1963c-10's Avatar
Re: Trim questions
Sodium Hydroxide will strip anodizing right off aluminum. Key ingrediant in Drano. Just be sure to do outdoors because of the fumes. 1TBSP per gallon water
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
