Old 11-27-2011, 08:20 PM   #1
bedfordia
is there an easy way to ungunk up a carb?
We'll i should know not to leave fuel in the carb for 9 months without running it but apparently i forgot that lesson and did it anyway. well to make a long short, my 63 will start and run for about 10 secs and then quit, the fuelpump pressure is ok and the bowl is filling with fuel but no run. also sprayed starting fluid in carb and kan keep it running that way so i don't think its a spark issue. could the jets have plugged and if so is there a way to clean them?
bedfordia is offline   Reply With Quote
Old 11-27-2011, 08:50 PM   #2
Dusty457
Re: is there an easy way to ungunk up a carb?
there is some stuff calle Mechanic in a bottle you can get it a home depo just drain the carb of the old fuel pour this stuff in the bowl and let it sit for a day or so it will soften the gunk used it on my generator in a motorhome and it worked great
Dusty457 is offline   Reply With Quote
Old 11-27-2011, 10:07 PM   #3
'63GENIII
'63GENIII's Avatar
A couple bottles of fuel injector cleaner works pretty well too. I use it on the little gensets I have when the carb bowls get a little water in them.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 11-27-2011, 10:46 PM   #4
bedfordia
Thanks guys i will stop by my local wally world tomorrow and see what i can find
Old 11-27-2011, 11:36 PM   #5
ironcrossmike
ironcrossmike's Avatar
The best way is to take the carb apart and use liberal amounts of Chemtool and a torch tip cleaner for the jets.
ironcrossmike is offline   Reply With Quote
