Old 11-27-2011, 08:43 PM   #1
keg
parking lights don't work?
1987, parking and side marker lights do not work. Tail lights, brake lights, turn signal lights, emergency flasher, dash,interior and head lights all work normal, just no parking or side marker lights.
keg is offline   Reply With Quote
Old 11-27-2011, 09:37 PM   #2
Your41Plague12
Your41Plague12's Avatar
Re: parking lights don't work?
Still sounds to me like a bad headlight switch. Maybe check to make sure the contacts are all good at the switch, clean them up if necessary.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 11-28-2011, 05:32 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
had that happen cause the plug came out of the switch a bit
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-28-2011, 05:41 PM   #4
bikes&bowties
bikes&bowties's Avatar
My marker lights didn't work so I took metal and a welder and removed them. Less lights can be tasteful
bikes&bowties is offline   Reply With Quote
Old 11-28-2011, 05:47 PM   #5
john_p
i would pull the bulb, check for voltage... follow the wire, does it go to the fuse box or have an inline fuse.. if it has neither and goes to the light switch, then it is the light switch.. one hot goes to the switch and IF that is the only wires that have no voltage.. it is the switch..
john_p is offline   Reply With Quote
Old 11-28-2011, 10:42 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
87 it should go to the fuse box
could unplug it at the firewall ,
slip/wrap a wire round a fuse nib or wrap wire to both sides and try to test the brown wire should work from there(to the lights) just now be sure to use a fuse
John
Old 11-29-2011, 12:02 AM   #7
keg
thanks for the responses. I found the problem, turned out all 4 lights were burned out, just the turn signals were working. Everything was working ok before I painted the truck, can't think of anything I did that would cause them all to burn out.
Old 11-29-2011, 02:56 AM   #8
john_p
that would be the work of Murphy, he loves his little jokes
