I need a compressor
So I've decided to take the plunge and paint my truck myself. Looking at compressors and need to know what size to look for. Found a decent 23 gallon on Craigslist for a good price. Will this do?
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
![]() Join Date: Oct 2009
Re: I need a compressor
personally, I wouldn't buy a used one. I've always looked at a compressor as a long-term investment and have not been disappointed (so far at least). Again - thats just me - however, if you do buy used, I'd certainly buy a quality name-brand unit.
Size required depends on what you want to do with it. But size is not as important as cfm rating, etc. Size (as in gallons) really just affects how often the compressor will kick back on while you're using it. If you go small, it'll run almost constantly if you do heavy duty stuff. To give you an idea - I have a 22 gal craftsman that will put out about 120 psi. I've had it for almost 25 years, still works great. I've painted with it, but mostly use it for air tools, etc. For painting, it's sufficient for regular old painting and should be just fine for hvlp. As for air tools, such as an impact wrench, for example - it'll kick on and run the pressure back up about 2 times during a regular 4-wheel tire rotation (with output pressure set at about 60 psi). I would maybe like a little bigger vertical tank with a little more hp (forgot to mention, mine is 5 hp). BUT, it's lasted this long, and if it crapped itself tomorrow, I could not complain, it's been a great tool for all these years. Whatever you do, I do recommend installing a line filter/drier, will save your compr and tools over time. Hope that gives you a starting point to compare what you need to what you're looking at. Good luck! |
That is probably too small to maintain an even pressure and volume at the gun. I know that all three paint guns I have use a lot of air.
![]() Join Date: Apr 2009
I got a 20 gallon and its not big enough. GO BIG. And like jocko said, buy a reputable brand. My devilbiss is great, just wish it was bigger. High rpm air tools will suck it dry.
Posted via Mobile Device |
Get the largest one you can afford if you want to run air tools like sanders, grinders, and maybe do some sand blasting. Those things suck a lot of air. Also the oil-less type make a lot of noise and from my experience don't last as long as a belt driven compressor. The price difference between a small one and one with a sixty gallon tank with a belt driven compressor isn't that much so that's what I would go for. Buy a good one now and you probably won't ever have to buy another one.
some good advice about a compressor on here from the guys.. cfm's are what you need to look for if you're going to use air tools, and paint.. Like the guys said get the biggest one you can afford and you'll be set for a long time... I've got the Sears 60 gal upright and it's served me well painting and using air tools..
![]() ![]() Join Date: Nov 2008
Basically you're gonna use an HVLP gun - High Volume (CFM or Cubic Feet per Minute), Low Pressure. So you're gonna need a LOT of air and a 20-something gallon tank ain't gonna get it.
My old oilless compressor died a couple months ago and I wanted a much larger - I DON'T plan to paint my truck but I may primer it. I had pretty much decided on THIS one: http://www.harborfreight.com/5-hp-60...sor-93274.html But it was pricey for my budget and I kept looking and looking and finally bought the same unit used in great condition for $265 off of Craigslist. The deals are out there but you've gotta check often and have cash in hand when the ad comes up. The used unit I bought: ![]() PS: I agree with Jocko above about buying new; it's likely a lifetime purchase. I just couldn't afford to at the time and my existing compressor wasn't working. I may flip this one next year post-tax return time and buy a new even larger unit. |
Not planning on running any air tools, just painting the truck.
#9 | |
These are the cheapo guns I bought and notice the pressure used is low, but 3+ (the touch up gun in the set -and you're not gonna paint an entire vehicle with one of those) to 7+ CFM is too much for a little 20-25 gallon compressor to continually provide. http://www.tcpglobal.com/spraygundepot/tcpgate.aspx Just offering my 2 cents. Maybe someone else will chime in with a different suggestion. PS: The more expensive guns just use MORE air. |
Certified Car Nut
SpeedAire compressor
http://www.grainger.com/Grainger/SPE...E97?Pid=search Grainger Branch: 553 809 Middle Ground Blvd. Newport News, VA 23606-4209 Phone: (757) 873-7600 Fax: (757) 873-3229 |
I had a Craftsman 30 gal oilless that burned up in a year of non-stop running. I have a Speedaire 23 gallon that would never keep up with my die grinders. It was enough to paint with a gravity feed spray gun but did run more often. I now use a 60 gallon Kobalt compressor that has no problems keeping up. Ever. With any tool I put on it. The only problem I have is that when my air dryer blow down valve pops off I have to stop spraying for a second because of the massive pressure drop. So far has been no big deal. My father in law has built several cars with his Ingersoll 60 gal and it's been plenty. I'm guessing that a 60 gallon seems to be a better size for the do it yourselfer.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
#13 |
I bought a 60 gal Kobalt compressor about 2yrs ago and I wish now I had bought the 80 gal. It is good most of the time but when i was sand blasting the 80 gal would have been nice and using grinders it would kick on less.
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
#14 |
jimig,
I'm certain you're right but I stumbled upon a deal on a 60 gal. that was too good to pass on. I intend to run a standing blast cabinet too and a small siphon feed Sears blaster too occasionally. That's why I'm thinking I may resell the 60 gal for a bit of a profit and buy an 80 gal in the Spring. I'm wondering if we scared off the OP with all this talk of a 60 or an 80 gal unit. They're expensive if you thought a 25-30 gal could work; and if you don't have the budget, you don't have the budget. We all can relate. |
#15 |
Nope, still here taking it all in.
#16 | |
#17 |
One other thing to think about is your electrical the bigger compressors will require 220V
#18 |
Yep. I was looking at that. Don't have a 220 outlet in the garage and with the house being a rental, doubt if the owner would let me run one. I was hoping that the one I found would work if I took my time. Just looked a a 25 gallon with 5.5 hp, 7.4 cfm @150 psi. I had looked a a gun that was rated at: 6 CFM @ 30 PSI.
#19 |
Yeah, without 220v, you're not going to get "big air". Sounds like what you've found may be the best available compromise.
If that's what you're working with maybe plan out your approach to spraying so you take on one fender, panel, etc at a time to minimize "waiting-on-the-compressor-to-catch-up" issues. |
#20 | |
I had a friend once who didn't want to make any wiring changes to his house so he made up an extension cord with a dryer plug on one end and dryer outlet on the other. He would unplug the dryer and use the extension cord when the wanted to run his compressor. |
#21 |
Is it an oilless? Usually a 26 or 30 gallon iron pump uses a 2 hp motor. Most electric motors switch to 220v or three phase above 2 hp. My oilless said 5.5hp on the tank but it took 15 minutes to air up. One of those would get you by in a pinch for paint if you didn't mind waiting while it runs. If you have to go 110v at least try to get one with an iron pump.
#22 | |
Hey, not to hijack, but I also don't have a 220v line to my detached garage, HOWEVER....I DO have my AC unit right next the garage; which of course uses 220. Anyone know if I could just disconnect that 220, run the wires to a sub panel and then use two circuit breakers in it? One to run the AC unit and the other to run the 220v compressor I have? The existing AC unit lines run back to a subpanel on my household service as it is, so this would be a sub-panel-to-a-sub-panel situation. I'm no electrician, but I have wondered if this is ok? Any advice appreciated. - Dan |
#23 |
Certified Car Nut
The difference between that 60 gallon and the 80 gallon is really not what makes it a better compressor. Most of your 80 gallons are 2 stage compressors. With the 2-stage compressors one piston pumps air into a second cylinder that further increases pressure. If you had a 60 gallon 2 stage like I do you would not even feel the difference between the 60 and the 80 gallon although there is more air in the 80 gallon tank the the difference would be slight. I bought a 60 gallon 2 stage for space (most 60 gallons are single stage) if I had the space I would have gone 80 (more choices and easy to find). A 2 stage does not work as hard and is very quiet. I can talk on the phone while my compressor is running and hear just fine. Stay away from those oilless compressors they are loud and do not last as long.
#24 | |
I am sure an electrician would blanch at my thoughts, but oh well.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
#25 |
If your box has a couple blank spots it's not too hard to add a 220 breaker and run some wire to a new outlet. They have special boxes just for adding an outlet in an old construction situation. That's what I had to do.
