Old 11-28-2011, 02:10 AM   #1
JRANGER
JRANGER's Avatar
New Member with Project
Hey Everyone! I just bought a 1978 GMC C15 High Sierra for $1500..It has a new 305 Crate engine that has about 38,000 miles on it. A rebuilt 350 turbo auto trans, new radiator, working heat, new carb, a new front end, kenwood cd, 6x9 rear speakers, a sub, mtx box, and probably a bunch of other new stuff. The guy I bought it from had bought it from his cousin who was got a divorce and couldn't keep all his projects anymore. I just haven't went through the receipts of all the new parts that he left for me. So needless to say its a strong running truck that I can work on and drive for the winter instead of my mustang.
So that was the good...The bad is the driver floor pan is rusted half out, the defroster doesn't work, the rear bumper and tail gate have surface rust, there is some rust in the driver side front wheel well near the bolts, and the dash lights don't work
So far I haven't found much diagrams on wiring for this vehicle so if anyone can direct me where to find that I would greatly appreciate it. Im not exactly a mechanic but Im great with electrical, body work, and a extremely fast learner.
So far I have order an h4 headlight conversion kit to make the truck more drivable at night and a driver side floor pan to.
JRANGER is offline   Reply With Quote
Old 11-28-2011, 02:59 AM   #2
GMC Guy
GMC Guy's Avatar
Re: New Member with Project
nice looking project, but you may have more feedback if you post in the 73-87 section
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 11-28-2011, 03:17 AM   #3
JRANGER
JRANGER's Avatar
wow, could of swore thats where I had this...Opps Thanks!
Old 11-29-2011, 05:11 PM   #4
jb1016
"Oh well, it's a driver."
jb1016's Avatar
Yeah, wrong section, but welcome to the board anyway, from another Nashvillian. Good luck with the truck!!
Old 11-29-2011, 05:12 PM   #5
JRANGER
JRANGER's Avatar
Thanks Too bad it decided to fail emissions after a month...Just dont understand how the guy had it hitting 3 on CO and now its hitting 7...Damn davidson county lol
I knew i was going to have to get into learning this engine soon but dang already
Old 11-30-2011, 12:33 PM   #6
jb1016
jb1016's Avatar
Here's what's worked for me...change the oil before you go, take the interstate and "blow it out" real good on the way -- get it good and hot, and make sure you go when there's no line -- you can just drive right up and go through, so you don't have to idle for long. But if you're putting up 7s, you might be needing a new catalytic converter. Good luck!
Old 11-30-2011, 02:58 PM   #7
JRANGER
JRANGER's Avatar
So here is what I found out from the receipts....
April 2003
The 350 engine was replaced with a C305/5.0L
80-84 Chevy Oil Pan
Chrome Chevy Valve Covers
May 2003
600 CFM Elec Choke Zinc
Trans Pan TH350
August 2004
New Radiator
March 2005
Diff BRG
Wheel brg
Wheels Seals
Drum HDW Kit
Brake Hoses
Disc Pad Set
Hub & Rotors
Calipers
April 2006
Coil Springs
Ctrl Arm Bushings
Idler Arm
Ball Joints
ADJ Sleeve
Tie Rod ENDs
2010
Heater Core
Mech E Pump
Fuel Hose
Jan 2011
Dist Cap
Dist Rotor
PCV Grommet
Spark Plugs
IGN Wire Set
So needless to say the guy rebuilding it put a lot of work and maint into rebuilding her
