New Member 78 C15 High Sierra
Hey Everyone! I just bought a 1978 GMC C15 High Sierra for $1500..It has a new 305 Crate engine that has about 38,000 miles on it. A rebuilt 350 turbo auto trans, new radiator, working heat, new carb, a new front end, kenwood cd, 6x9 rear speakers, a sub, mtx box, and probably a bunch of other new stuff. The guy I bought it from had bought it from his cousin who was got a divorce and couldn't keep all his projects anymore. I just haven't went through the receipts of all the new parts that he left for me. So needless to say its a strong running truck that I can work on and drive for the winter instead of my mustang.
So that was the good...The bad is the driver floor pan is rusted half out, the defroster doesn't work, the rear bumper and tail gate have surface rust, there is some rust in the driver side front wheel well near the bolts, and the dash lights don't work So far I haven't found much diagrams on wiring for this vehicle so if anyone can direct me where to find that I would greatly appreciate it. Im not exactly a mechanic but Im great with electrical, body work, and a extremely fast learner. So far I have order an h4 headlight conversion kit to make the truck more drivable at night and a driver side floor pan to. |
Re: New Member 78 C15 High Sierra
welcome! thats not a hole thats an evidence locker, as far as the dash lights go start with new bulbs and then look at the circit board on the back of the gauge cluster they have melt downs every now and then and if all thats good replace the headlight switch the restat goes bad in them
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
![]() Join Date: Jul 2010
welcome
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
78K & 79C Jimmys
hello
looks like a great start http://forum.73-87chevytrucks.com/sm...?topic=11766.0 should cover some wires and stuff for you
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
awesome! Can you guys tell me where the high beam switch is on this truck? First GMC and first older model sorry im a rookie!
Push button on the floor JRANGER.
Looks like a good ole truck. |
So here is what I found out from the receipts....
April 2003 The 350 engine was replaced with a C305/5.0L 80-84 Chevy Oil Pan Chrome Chevy Valve Covers May 2003 600 CFM Elec Choke Zinc Trans Pan TH350 August 2004 New Radiator March 2005 Diff BRG Wheel brg Wheels Seals Drum HDW Kit Brake Hoses Disc Pad Set Hub & Rotors Calipers April 2006 Coil Springs Ctrl Arm Bushings Idler Arm Ball Joints ADJ Sleeve Tie Rod ENDs 2010 Heater Core Mech E Pump Fuel Hose Jan 2011 Dist Cap Dist Rotor PCV Grommet Spark Plugs IGN Wire Set So needless to say the guy rebuilding it put a lot of work and maint into rebuilding her |
