Not too old to learn
Mufflers Quiet or Loud ?
Anybody running Summit Turbos ?
Are they quiet or extremely loud with a stock 350 and stock ram horns dual exhaust ? I know they are cheap $38 each , but I'm ready to fire up my new crate engine and if I buy a set of more expensive ones, and don't like them, there goes $ What I want is a nice low rumble at low speeds and at cruise hiway speeds....... very quiet. I have feeling I'm answering my own question. ![]()
1968 C10 a way to long restoration. |
Re: Mufflers Quiet or Loud ?
I have them on my El Camino and love them. 355 Vortec heads, 9.5 comp, GM roller Hot Cam. Not too loud - Not too quiet. Just right....
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I have them on my LS swap, they are a little noisier that I like, but it tends to PO the neighbor so I kept them. I also had Cherry Bomb turbos and those were a little louder than these. I have heard that Magnaflow has some muff's that are right in the middle.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#4 | |
I want to stay away from any loud exhaust thanks for all the replies.
![]() ![]() Join Date: Jan 2011
Magnaflows sound really good. I had my 396 running for maybe 2min
![]() But .. yes, Magnaflows are pretty impressive. I usually run Flowmaster but just wanted something different. Flows kinda have a drone at low RPM, just a matter of taste I guess.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
Maybe a 50 series from Flow would be better, not loud at all unless you stomp on it.
http://www.flowmastermufflers.com/index.php?cat=1
I prefer Cherry Bomb glass packs but for reason I don't understand some people think they are obnoxious.
Quit if it's not FUN!!!
Posted my rear-mounted Thrush Turbo's here:
. http://67-72chevytrucks.com/vboard/s...d.php?t=491839 . Post #9 |
I've got what are probably cheapie muffler shop turbos on th 71 with tail pipes that exit behind the rear tires and there isn't a lot of noise at road speeds inside the cab unless you run along side a Johnson barrier with the window down. It has a good rumble sitting at an idle though and barks a bit when you really lay into it.
Registered Cruiser
I've got OEM style mufflers like these. 2.5 in X 2.5 out. They're real quiet, even with long tube headers, and flow just fine in a dual exhaust application. I had turbo mufflers for years. They sounded great. I must be getting old though, because anymore I like my quiet pipes.
I intend to live forever. So far, so good. |
#11 | |
but not in my cab. I'm checking out AP turbos. What are the costs of the Walkers ?
#12 | |
Bud |
#13 |
Registered Cruiser
I think they were $33.00 ea. for the OEM style.
#14 |
I put a set of Super Traps on my '65 Mustang and there was nothing that sounded like them. The closest thing I could compare the sound to was a boat witha pumped engine with the exhaust coming out the back at the water line. Kind of a "blub blub blub...." with a deep sound. They have a much nicer sound than the flow masters on my Dodge hemi. Plus, they're tunable by adding or removing the plates.
#15 |
i like reasonablly quiet systems too, i generally buy generic turbo mufflers from local autoparts store
to me nothing funnier than guys runnin blowmasters and they step on it make a lot of noise and still cant get out of thier own way
