11-28-2011, 05:42 PM | #1 |
rad suppoprt mounting brackets
I notice that some are solid (all steel) mounting to the frame while others have a laminated rubber insulator sandwiched in them. is there any rhyme or reason to what years, makes or models that these applied to;
ron Last edited by padresag; 11-28-2011 at 06:12 PM. |
11-28-2011, 06:06 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: rad suppoprt mounting brackets
Which year are you working on? I know the 64-66 Chevy has a cross member that the U-shaped metal mounts are bolted to, then a formed U-shaped rubber cushion sets in there to protect the rad. This is the only way I have seen the 64-66 so if someone knows something I dont....
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-28-2011, 06:14 PM | #3 | |
ron |
11-28-2011, 06:28 PM | #4 |
Check The Champ, Demonstrator
Sorry Ron, no where near my parts book to look that up. The 60-61 exploded view shows more hardware than the 63 exploded view.
11-28-2011, 06:34 PM | #5 |
I did, and that is how I understood your question.
11-28-2011, 06:48 PM | #6 |
11-28-2011, 06:50 PM | #7 |
[QUOTE=aerotruk63;5035754]Sorry Ron, no where near my parts book to look that up. The 60-61 exploded view shows more hardware than the 63 exploded view.
Norm; re the photo that you just put in under rad guard(another thread) of the 4 x 4 frt end(parts truck) you will notice the rad support brkts just above the frt spring hanger. that one is solid, but there are lots that are insulated. ron Last edited by padresag; 11-28-2011 at 06:56 PM. |
11-28-2011, 06:59 PM | #8 |
Nice turned bowls Ron, by the way.
11-28-2011, 07:09 PM | #9 |
11-28-2011, 07:33 PM | #10 |
Sorry didn't know where my head was. 1.286 Bracket correct? Never owned or paid attention before to GMC's.
11-28-2011, 09:02 PM | #11 |
out of 5 of them (these trucks) i have only seen one solid set . on both chev and gmc. the soid ones were on an American GMC(62 3/4t)
ron |
11-29-2011, 02:06 AM | #12 |
60-66 Nut
It has been my experience that only the Suburbans and Panels had the rubber bonded radiator support mounting brackets. I've not seen those on any pickups.
11-29-2011, 03:05 AM | #13 |
thanks Capt. it is understandable that 4 of the 5 have been panels and suburbans
ron |
11-29-2011, 10:37 AM | #14 |
my 60 and 62 burbs have the rubber/washer/triangular washer/bolt setups, need a pic?
11-30-2011, 07:25 PM | #15 |
I was at Bills Truck Shop in Courtice Ontario today and we were talking about this site. This frame had a Chevrolet Cab on it. He did not think the cab was original to the frame. Thanks Ron for brining this to our attention.
11-30-2011, 07:35 PM | #16 |
11-30-2011, 07:54 PM | #17 |
that is just a rare way of spelling solid, that's all. so that those fellows down in mo. would understand it!
ron oops, I better watch that , I got my Chesapeake Bay Retriever out of Mo. and he is pretty smart |
11-30-2011, 11:24 PM | #18 |
yep MO. SHOW ME STATE, SHOW ME 1960K-20
11-30-2011, 11:57 PM | #19 |
12-01-2011, 12:16 AM | #20 |
rare would be not many left of the 1s stamped
12-01-2011, 12:17 AM | #21 |
never said rarest of them all that came from you bud
12-01-2011, 01:36 AM | #22 |
60-66 Nut
So is this frame a pickup frame or a Suburban/Panel frame?
12-01-2011, 08:08 AM | #23 |
oh THOSE mounts! Never saw the rubber ones! All my GMC's have solid ones! I do have a spare on a frame in good shape.
12-01-2011, 11:27 AM | #24 |
This was attached to the trailing arms on the same frame. Trailing arms were only Chevrolet correct? Should ask Bill if this truck was brought up from the States or was in Canada. Look at the frame how clean it is though.
12-01-2011, 12:01 PM | #25 |
I believe that they were an option on GMC, as springs were on Chevrolet.
It must have been one of those Ca. trucks ron |
