73-87 10inch lift
Besides 10 inch springs and shocks, what do i need to change other then brake lines and tcase drop? Like what steering components need to be switched?
Thanks david. Posted via Mobile Device |
Re: 73-87 10inch lift
I beleve crossover steering will be a great addition.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
Alright ill have to look into prices.
Do you think my drive shafts will be fine if i do a 2 inch tcase drop? Posted via Mobile Device |
Nope. I also wouldn't recommend doing a T-case drop. I did one on mine, and I regret it. It helps the rear driveshaft but actually hurts the front. If you use 4x4, which I'm assuming you do, prepare to be busting U-joints left and right. You're going to need longer driveshafts with that much lift, no two ways about it.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
#5 | |
Grease Monkey
I'd clock it, and buy a High Angle Driveline from the experts, High Angle Drivelines.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
http://offroaddesign.com/catalog/6boltclockingrings.htm
Offroad designs clock rings seem pretty cheap and they just came out so i haven't heard much about them
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
will drive shafts need to be lengthend with only an 8?
Collector of Projects
4" max lift with stock drive shafts... I would also suggest crossover steering ... what size tires will you be using? Why would you want a lift that big? 10" springs are going to ride like and empty dump truck... hell my 4" lift rides rough...
yeah ur gonna need custom drive shafts
dont know what axles u running but ur gonna need 1 tons if u want reliable and tires to go with 10" lift |
I dont agree.. im running 6 inch with stock driveshafts and they are plenty long enough
1977 K10 shortbox Scottsdale 4x4 1988 C30 Crewcab Silverado 1987 K10 longbox Silverado 4x4 1969 GMC 1500 4x2 |
