Old 04-20-2003, 08:38 PM   #1
67_396
Arrow 4 link suspension??
Do any of you run 4-link suspension in your truck? If so, what changes did you do to make everything work? Also, I would like to see pictures of how you did your set-up. Thanks
67_396 is offline   Reply With Quote
Old 04-20-2003, 08:57 PM   #2
Reumster
L.E.D. Freak
Reumster's Avatar
To tell you the truth you won't see many 4 link suspensions on 1/2Ton 2wd 67-72 because the trailing arm suspension is allready awsome. It's actually better than most 4 link set-ups.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 04-20-2003, 09:00 PM   #3
Alvin
Never Done?
Alvin's Avatar
I'm planning on running an AirRide Triangulated four-link to replace my leaf springs. So they are a good option for those of us not blessed with coils! Oh how I wish I had a coil frame though :p Anybody got any info? I'd love to see one installed. Thanks
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 04-20-2003, 09:04 PM   #4
Randy70C-10
Randy70C-10's Avatar
If you run a high-horsepower engine you want to use a prostreet 4 link set up. If you don't , you'll twist the rearend clean out from under the truck. (I saw a t-bucket do this)
Randy70C-10 is offline   Reply With Quote
Old 04-20-2003, 09:49 PM   #5
flyin99
creator of kong
flyin99's Avatar
the way I had mine done
flyin99 is offline   Reply With Quote
Old 04-20-2003, 10:13 PM   #6
Randy70C-10
I shoulda bought that truck......if I only had somewhere to keep it.
Old 04-20-2003, 10:23 PM   #7
flyin99
creator of kong
flyin99's Avatar
Woulda been nice if you could have Randy, but I understand about the lack of room thing..........been there done that.........already eyeballin the next one to start on though
Old 04-20-2003, 10:56 PM   #8
Crank
Crank's Avatar
Um, I'm gonna run a Triangulated 4 link, designed by me. It's gonna have bags. But talk to DR. LOW, he has a 4 link with bags. Truck will lay rockers I think.
Brandon
Crank is offline   Reply With Quote
Old 04-21-2003, 12:45 AM   #9
lost wages
lost wages's Avatar
im in the process of setting up a triangulated four link on my bagged 68 right now, one thing to consider is with a stock 12 bolt you CAN NOT weld the brackets to the pumpkin for the angled top bars, it is cast and will not penetrate, try welding something to it, youll see. Im going to run a narrowed 9 inch ford rear end on mine.
lost wages is offline   Reply With Quote
Old 04-21-2003, 02:50 AM   #10
72addict
You can weld it, but it is a pain in the gas (prices are high). The housing would have to be baked first to get the oil out of it, then while it was preheated, prepare the spot, then weld with the high dollar rod (welder at work told me it was about $60 a pound). It is easier to use a 9" definately.
1957 Cameo
72addict is offline   Reply With Quote
Old 04-21-2003, 10:10 PM   #11
cruzn72
My friend and I built a 4 link for my 72gmc. You can look at some of the install pics @ [http://photos.yahoo.com/bc/cruzn72@p....src=ph&.view=
cruzn72 is offline   Reply With Quote
