Old 11-29-2011, 07:06 AM   #1
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
1967-68 style light blue door panels
These are pretty rare and the vinyl is all in tact... Metal panel is great on one and slight rust on other... Have replacement metal panels as well... This vinyl could easily be removed and reapplied... it has held its color rather well...
$60 shipped ConusPanels sold to BuidinA68
Also have matching visors... great color with some stitch work needed... Lets talk
This package is listed elsewhere I might add
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline   Reply With Quote
Old 11-30-2011, 03:28 AM   #2
HeavyMetalChevy
Just a Member
Re: 1967-68 style light blue door panels
$60 shipped CONUS.. that's it
TH400(3rd)
Old 11-30-2011, 05:31 AM   #3
19Hoosierdaddies68
Heavy,
Whats up? I think you mentioned before you had these, I was wondering when they would show up. Im interested...Do these standard arm rest attach to the holes in the panels? Just want to make sure as I dont see the indents as if they had the standard arm rest installed before.
Also, they look a little lumpy bumpy under the vinyl, is that an optical illusion or what is under there causing that?
How much for the visors? Do you have pictures? Do they come with the hold down center clips and brackets in blue as well?
Thanks,
Jerry
19Hoosierdaddies68 is offline   Reply With Quote
Old 12-01-2011, 05:49 AM   #4
HeavyMetalChevy
Just a Member
Originally Posted by 19Hoosierdaddies68 View Post
Heavy,
Thanks,
Jerry
On the vinyl..it is not illusion.. there is something going on there but I am not sure what... It must be some rust issue but like I mentioned the real value is the vinyl... One metal panel looks good to go and the one that is "lumpy" is suspect but nonetheless the vinyl is in tact and good shape.. Here are visor pics... They have real good color just need stitch work... I am going to start tracking down a seamstress actually I have a female companion that would hook me up... I have quite a few high quality visors that just need a little TLC and they will be immaculate!!! These panels and visors were one year only 67 actually so they are rare I believe.. of course the panel pattern is 67-68 style.. The parts wizard himself told me so... Yes he does exist!! of course the panel pattern is 67-68 style..I am trying to track down paint code .. its not quite light blue or medium blue poly but closer to dodge fact color arctic blue... Need to know..
TH400(3rd)
Old 12-02-2011, 08:13 AM   #5
19Hoosierdaddies68
Heavy,
I think you are right in these being 67, based on an amateur analysis of mine as it looks like the arm rest would have been the 64-67 style, according to Brothertrucks.com pictures and descriptions, haha.
I would be putting these in my 68 so would like to confirm if the 68 style armrest I pictured before will bolt to these without issue? or other holes being exposed etc.
Is the vinyl in the pictures on the door panels already cleaned up? Or could they be better with additional cleaning?
The sunvisors look a little rough, maybe cleaned up and stitched back together they would present better in the pics. How much you looking for for those? They came from the same 67 truck? Would price include the stitch work or without?
Old 12-05-2011, 09:15 PM   #6
HeavyMetalChevy
Just a Member
ttt
TH400(3rd)
Old 12-05-2011, 09:25 PM   #7
BuildinA68
BuildinA68's Avatar
i'll take them!!!
pm sent
Ryan
BuildinA68 is offline   Reply With Quote
Old 12-05-2011, 09:27 PM   #8
BuildinA68
BuildinA68's Avatar
pass on the visors though.
Ryan
Old 12-05-2011, 09:44 PM   #9
HeavyMetalChevy
Just a Member
ttt for cleaned visor pics...
TH400(3rd)
Old 12-09-2011, 12:51 AM   #10
HeavyMetalChevy
Just a Member
TH400(3rd)
