Is there a step by step for 73-87 rockers?
Is there a step by step for 73-87 rockers? I've done a couple 67-72, but I have some questions on my 87, which needs rockers and cab corners. I've been rooting around, but havent come up with anything. Any help is appreciated. TIA, Chip.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
![]() Join Date: Apr 2009
Re: Is there a step by step for 73-87 rockers?
Thanks for the lead, hope I can figure it out. Worst come to worse, I'll just bust out the zip wheel and get ta whackin'!
Only thing I might add to the build shown, first thing I do is either bolt in or tack weld a brace from one door post to the other which helps hold things where they were before the rockers were cut out. Also, instead of overlapping the joints I make small steel tabs to bridge between the old/new sheet metal and mount them under the sheet metal with 1/8 inch pop rivets. That way the weld is a butt and gets the new metal exactly lined up with the old instead of the overlap. Then I blow out the rivets with the torch and weld up the holes. (I weld with gas rig.)
