Old 04-20-2003, 09:24 PM   #1
BUXMAN66
go bucks!
got my new tilt column in !!
w/ a lotta help from the board members especially....junkyardjohn! thanks for the info.,guys.love this board and all the info i've gotten off of here!just gotta install my new grant sig.series steering wheel yet.thanks again to all that helped me.
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 04-20-2003, 09:29 PM   #2
kingparts
kingparts's Avatar
This board is truly amazing. You post what you need and in no time somebody has it and usually at a good price. I have to put my tilt in I got from somebody on the board.
David
1970 Chevrolet Suburban
1967 Chevrolet C/10 Shortbed Stepside
kingparts is offline   Reply With Quote
Old 04-20-2003, 09:49 PM   #3
BUXMAN66
go bucks!
good luck w/ it.....it's wasn't really too hard to actually put in.mine was a van column,so i had to lower the back-up/neutral safety switch 7" further down the column. i had to do some creative dremel work also to open up a slot in the outer column,and then again in the inner column for the tang of the back-up light switch to ride in.got some new rubber gaskets also,one for the firewall and one at the column metting the dash.fine69(board member),came thru w/ a intermediate shaft to link up the column's spline shaft to my rag joint.
