Old 11-29-2011, 12:40 PM   #1
kw
kw's Avatar
88 Suburban--shattered tailgate window
Saturday I was loading up the Suburban for a run to the local dump. The tailgate, when I initially closed it, hung up on some cardboard, I moved it and shut the tailgate. Then I heard the little pieces of glass falling into the bottom of the tailgate. Yup, busted rear window.
I have no idea how it happened, and now the tailgate is jammed shut. I took off the panels and guess I'll have to pull the rods to manually open the tailgate.
Have any of you had a rr window shatter, and what caused it? I'd hate to get a new piece of glass only to see this happen again.
Thanks in advance,
Kurt
kw is offline   Reply With Quote
Old 11-29-2011, 02:38 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: 88 Suburban--shattered tailgate window
I had my door glass shatter on me not too long ago closing the door. Not fun at all.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-29-2011, 03:30 PM   #3
low88burb
my back window did on mine when i was going onto a bridge and sup. bottomed out !
low88burb is offline   Reply With Quote
Old 12-02-2011, 05:56 AM   #4
62 Longbed
62 Longbed's Avatar
I recently broke my rear glass on my 1986 Suburban ... My side latches were loose so when I closed mine one side caught and the other side didn't , so I slamed it harder hoping it would catch .. then heard the shattering glass as it fell into the gate . @%#$^ !!!!! Had tinted glass , but found cheap clear replacement if it happens again ...
62 Longbed is offline   Reply With Quote
Old 12-04-2011, 07:53 PM   #5
6 Door King
Check the clearances around your window channels, most auto glass will not shatter if hit on the face, but on an edge it will explode. I would look for a stray bolt or exposed point that my have blown the glass. If you care to head south, I have a tinted glass you can have as a leftover from my crew cab conversion.
1954 3100 Nova Subframe, Pontiac Posi, roller for now1967 C-10 SWB 350/350/Posi. Soon to be Crew Cab!
1978 Crew Cab Dually roller
1982 C-30 Rollback, 454, 4 speed
2004 K1500 Suburban Z71 5.3 Kid Mover
6 Door King is offline   Reply With Quote
Old 12-06-2011, 10:15 PM   #6
kw
kw's Avatar
Thanks all.
6 Door King I sent you a bmail re the window.
Kurt
