11-29-2011, 12:44 PM | #1 |
blinker/brack prob
Way are my blinkers coming on in the front when i hit my brakes.is that a ground prob?
Posted via Mobile Device |
11-29-2011, 01:21 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: blinker/brack prob
did that just start? sounds like a couple wires got crossed.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-29-2011, 03:36 PM | #3 |
No it been like this since i got it about 6years ago
11-29-2011, 04:25 PM | #4 |
1# Drobmember in Germany
Maybe you have wrong bulbs in the taillights!
Pat |
11-29-2011, 05:19 PM | #5 |
might check the bulbs in the brake lights, when i got my 66 someone put a single pole bulb in one of the brake lights so it was touching the brake and running lights terminals so when i stepped on the brakes all my dash lights and front running lights(both front blinkers on at same time) would light up switched bulb and everything worked fine...
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
11-30-2011, 11:23 AM | #6 |
Ill check the bulb
