Cleaning out lower cowl
What is the best way to vacume out the area in the lower cowl behind the kick panel area? I was going to put a hose down through the vent but there is a piece that blocks off the bottom.
70 CST Bunch of old Camaros ![]() |
Re: Cleaning out lower cowl
After getting most of out with my hand, I just used compressed air. Most of that crap will fall out from the bottom around the rear of the fender. Then I went underneath and blew out the rest left behind.
I cut the bottom out of that vent. I put a 12" bi-metal blade on a sawzall and went in through the opening between the hinges on the door and the fender and started near the kick panel and cut up and out until I ran out of metal. Now, it is wide open for leaves, pinestraw, water or whatever to fall straight on through. Just be sure to check and make sure that is not part of the factory air system, I am not too sure about that part of it. Works well for me.
No one ever fell to the top of a mountain. When asked why I work on old trucks, I tell them: Been married 27 years, sons are pretty much gone, don't like the wife anymore and don't have a girlfriend, so, gotta do something, the old trucks are cheaper and less drama than a girlfriend - ![]() |
![]() Join Date: Sep 2004
I used this attached to shop vac.
Daily-94 K2500 350 5spd extended cab longbox Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack. Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881 My 01 TA and 88 Formula hide in the garage. :-) |
