Old 04-20-2003, 09:52 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
87 IROC Z 305 TPI setup on 72 350
I recently bought an 87 IROC with a 305 TPI and auto overdirve tranny. I plan to replace the carb set up on my 350 72 GMC truck with the TPI system from the IROC. I will also use the auto overdrive tranny out of the IROC. Has anyone done this that can lend technical support and maybe an e-mail address? I am thinking about using 24 lb/hr Bosch style injectors and use a Painless Wiring harness. Any help would be greatly appreciated. Thanks, Greg
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 04-20-2003, 09:53 PM   #2
Dean23
68cst_ss490
Dean23's Avatar
sounds like a wicked upgrade. keep us posted on how it runs and how the change over goes
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 04-20-2003, 11:04 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You'll want to upgrade the throttle body too, you'll be feeding 45 cubes more.
I would look into spending some good money on that 700 before slapping it in there. They are known for falling apart.
Also when installing it, get the instalation kit that includes the oil pressure guages, don't just adjust the TV cable per Chilton's instructions. It does more than just kicking down the gears, it also regulates the oil pressure.
Old 04-20-2003, 11:10 PM   #4
dtlilly
dtlilly's Avatar
I recently bought a TPI set-up from an 86 Iroc with a 350 (intake and all wiring/computer). Then I found out I needed to use TPI heads as well, so I sold everything at the Super Chevy last weekend.
I don't know if that is the same in your case.
dtlilly is offline   Reply With Quote
Old 04-21-2003, 09:45 AM   #5
Mike C
Mike C's Avatar
The 85-86 TPI setups, and all of the aluminum head Corvette TPI setups, use the regular 69-86 bolt pattern. 86 used centerbolt covers with regular intake pattern. The 87 and up TPI setups on the Camaro have the center intake bolts at a different angle. It is possible to slot the bolt holes and use it on the older heads.
The throttle body is not a source of restriction, at least early on. What you do need is a set of 22 # injectors from a 350. Stock LT1 injectors are a good choice for 350 TPI motors. IF you are going to buy new, Ford Motorsport is the cheapest, with Accel not far behind. About $225 a set of 8.
If you are going to have to buy an intake, check out the Vortec TPI intake that Scoggin DIckey has and go ahead and upgrade to Vortec heads when you do the TPI swap.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-21-2003, 03:09 PM   #6
smokekiki
Mike
smokekiki's Avatar
Check out www.chevythunder.com lots of info.He also makes wire harnesses cheap.Comps and chips too.You will need to decide if you want to keep the mass air flow,or switch to speed density.Speed density is less complicated,mass air flow is more forgiving when making mild cam changes and other performance changes.You can redo your harness or have chevythunder redo it.I got one of his harness and computers.Works great.175 for harness.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
