Old 11-29-2011, 08:17 PM   #1
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
1988 Chevy Suburban won't start after engine swap, fuel issue?
I took the oil burning engine out of my 1988 suburban and replaced it with an engine out of an 89 suburban that happened to be a newer Good Wrench replacement motor (350).
I have tried to start the engine and it seems to not be getting any fuel. If I pour some fuel into the throttle body it will run for about 15 seconds, but then it dies. I assume that I'm not getting fuel from the tank. Is there anything that I might have missed?
Both of the engines ran before the swap.
Old 11-29-2011, 09:33 PM   #2
joe231
joe231's Avatar
Re: 1988 Chevy Suburban won't start after engine swap, fuel issue?
Does the fuel pump run?
CHEVY ONLY
Old 11-29-2011, 10:46 PM   #3
jonzcustomshop
1961 crewcab
I am trying to figure that out, is there an easy way to tell?
Old 11-29-2011, 10:51 PM   #4
joe231
joe231's Avatar
Get someone to turn the key on while you listen at the gas tank filler with tge cap off.
There should also be a red "test" wire at the fuel pump relay on the firewall. You can supply that wire with 12 volts to see if the pump runs.
Have you checked all your fuses? Did you double check all the underhood wiring?
CHEVY ONLY
Old 11-29-2011, 11:00 PM   #5
ghettoluxury
ghettoluxury's Avatar
Make sure you have a power wire going from your battery to the alternator. I had this exact problem with my tbi motor, it would run if you fed it gas but would not stay running the battery cable was the problem.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-30-2011, 12:27 AM   #6
jonzcustomshop
1961 crewcab
thanks, I will check out in the morning, and get a report back!
Old 11-30-2011, 01:50 AM   #7
85sierraclassic
85sierraclassic's Avatar
check and make sure you oil pressure sensor is the same prong count if you didnt use the original they will still plug in but one has one less prong than thee other and wont turn on the fuel pump.
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline   Reply With Quote
Old 11-30-2011, 04:30 AM   #8
Jonboy
Slots go on anything!
If it is a bad oil pressure switch, you should still hear the pump prime when you turn the key on. The switch sends power to the fuel pump relay when it sees 3-5 psi of oil pressure (so it will shut off in event of oil pressure loss).
1974 Jimmy- 5.3/4L80e/NP241
Old 11-30-2011, 10:53 AM   #9
legendman
legendman's Avatar
Check your grounds too, missed the one that goes from the rear of the r/s cylinder head to the firewall when I did my motor swap on my 89 K2500.
Not sure if it was the cause because I cleaned up all the ground wires when I was troubleshooting then same issue.
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 11-30-2011, 08:31 PM   #10
jonzcustomshop
1961 crewcab
well, got it running... everything checked out, so I tried replacing the throttle body with the one off the oil burning 88.... put it on and it just fired right up! why? I have no idea... but it works....
now that you mention that rear ground wire... i think that got missed... will have to check that and install tomorrow....
on another note; with the swap, the air pump never made it back on the vehicle... (the 89 had smog free exhaust manifolds) MT. is an inspection free state, would I benefit from removing the cat. and putting a straight pipe in its place?
Old 12-01-2011, 12:30 AM   #11
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
My 90 V3500 Crewcab only has one O2 sensor and it's before the cat, so it doesn't know the difference if you take it out. I did. There was no noticeable difference.
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 12-01-2011, 09:02 AM   #12
jonzcustomshop
1961 crewcab
ok, mainly wondering how clogged up this cat might be from the previous oil burner
when I pulled the manifolds off, it looked like #2 cylinder was not firing, and just pumping oil into the exhaust!!
