11-29-2011, 08:53 PM | #1 |
70 GMC 4x4 ?
I have a 70 GMC4x4 1/2 ton 4 speed tranny not sure of transfer case. The question is: between the transfer case and transmission can the oil move back and forth with out restriction? Otherwise can the oil from the transmission get into the transfer case?
I checked oil in transfer case and it ran out like it was too full and transmission was not full enough. It took about a quart to top off. Thanks for any help. Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
11-29-2011, 09:29 PM | #2 |
Grease Monkey
Re: 70 GMC 4x4 ?
I am assuming you have a manual trans. The adaptor between the trans and t case (mostly likely a NP205) does have two seals that keep the fluids separate. Sounds like your seals are shot.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
11-30-2011, 11:34 AM | #3 |
20' Daredevil (Ret)
Re: 70 GMC 4x4 ?
Same problem occurs with TH350 coupled to a NP205..... seals go bad and trans fluid is pumped into the t-case. To the OP -- it doesn't flow both directions, though.
11-30-2011, 12:01 PM | #4 |
Re: 70 GMC 4x4 ?
I should be able to drop t-case to get to both seals?
Thanks Ron Posted via Mobile Device
11-30-2011, 11:12 PM | #5 |
Re: 70 GMC 4x4 ?
yes sir! ^
1970 C/20 4x4, 350, sm465, np205(She tipped over... total rebuild from the frame up!) ya gotta keep on keepin' on, Life's a garden, dig it! |
11-30-2011, 11:13 PM | #6 |
Re: 70 GMC 4x4 ?
get a jack or jack stand underneathe that trans to support it though cause the adaptor fromtrans to t-case is what bolts to that crossmember, which i think you'll have to drop down quick
11-30-2011, 11:21 PM | #7 |
Re: 70 GMC 4x4 ?
Thanks for help gents! Not sure when I wil lbe able to get to it for sure.
Ron
