Old 11-30-2011, 10:01 AM   #1
71sierragrande
Petroleum User
71sierragrande's Avatar
Is a vortec 6.0 in a 2004 escalade an LQ9?
I'll get pics up later but Im trying to find out what motor this is as I might want to switch it over to my GMC. Anyone know what trans might be in it? Its an ESV with all wheel drive long wheel base(133" I think).
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 11-30-2011, 10:22 AM   #2
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Re: Is a vortec 6.0 in a 2004 escalade an LQ9?
It might be the LQ9 in an escalade and it probably has the 4l80e tranny. Any of the 6.0 motors are great. However, the LQ9 does offer a little higher compression over the LQ4. The only way to tell is run the VIN or remove the heads and look at the pistons.
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 11-30-2011, 11:12 AM   #3
71sierragrande
Petroleum User
Pics probably wont help with all the plastic but here it is...[ATTACH][ATTACH][ATTACH]Name:  007.jpg
Size:  57.0 KB[/ATTACH][/ATTACH][/ATTACH]
Old 11-30-2011, 11:23 AM   #4
ls1nova71
ls1nova71's Avatar
If it's original to the Escalade then it is an LQ9, it will not have a 4l80e it will be either a 4l60e or 4l65e. They only put the 80's behind LQ4's and they ars only in 3/4 ton and up trucks.
ls1nova71 is offline   Reply With Quote
Old 11-30-2011, 11:25 AM   #5
71sierragrande
Petroleum User
Thanks for the help. Yes, its a great motor. I just recently hauled 8 tons with it(including itself), and it performed beautifully at all times. Put the hammer down and she gets right up the hills, no prob!
Old 11-30-2011, 11:28 AM   #6
71sierragrande
Petroleum User
Can u tell what the trans is if I show u a pic?
Old 11-30-2011, 11:35 AM   #7
ls1nova71
ls1nova71's Avatar
If you put up a pic of the pan I can tell you if it's a a 4l80 e or not, but there's no difference in appearance between a 60 and 65.
Old 11-30-2011, 11:41 AM   #8
jays68yak
jays68yak's Avatar
Just because it is in an escalade doesnt make it an lq9. The only true way to tell is to run the vin or check the pistons.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 11-30-2011, 12:13 PM   #9
ls1nova71
ls1nova71's Avatar
Never seen an LQ4 in an Escalade. All I've ever seen in them were LQ9 6.0's and 5.3's and later the 6.2's.
Old 11-30-2011, 12:14 PM   #10
71sierragrande
Petroleum User
[ATTACH][ATTACH][ATTACH]Name:  012.jpg
Size:  38.0 KB[/ATTACH][/ATTACH][/ATTACH][/ATTACH]
The first one is engine pan. Youre gonna laugh at these but its so low to the ground and not much room or light, this is the best I could do. These pics are pathetic but theres no room, I can barely even slide under it.
Old 11-30-2011, 12:21 PM   #11
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
If you can get me the last 8 of the vin I can give you any info. my computer has about it.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 11-30-2011, 12:25 PM   #12
ls1nova71
ls1nova71's Avatar
Can't tell by those pics but all the 80's I've worked on have a drain plug in them. Does yours? Also that 5.3 written in grease pencil looks like a salvage yard marking, has it been replaced?
Old 11-30-2011, 12:27 PM   #13
ls1nova71
ls1nova71's Avatar
There you go, I'm betting LQ9/4L60e. Now let's find out!
Old 11-30-2011, 12:44 PM   #14
71sierragrande
Petroleum User
It probably WAS replaced. The title even says "rebuilt vehicle", we did a vehicle history search a while back and it showed that the vehicle had been stolen in the past also. My dad bought it a few years ago and left it to me when he died. Ok, heres the last eight of the vin...4G316351. Thanks for the help fellas.
Old 11-30-2011, 12:53 PM   #15
BACKYARD88
BACKYARD88's Avatar
the VIN shows LQ9/4L65E.
-Mike Owen-
Old 11-30-2011, 01:24 PM   #16
71sierragrande
Petroleum User
Thanks, BACKYARD. ls1nova71, what do you think the 5.3 marking means? Switched motors?
Old 11-30-2011, 02:22 PM   #17
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Could be a date, or for 5.3 liter.
Doesn't the LS9 have an aluminium block?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 11-30-2011, 04:47 PM   #18
BACKYARD88
BACKYARD88's Avatar
USUALLY slavage yards mark the case on the hard parts. That little cover would be awfully easy to change or loose. I would guess that was put there possibly by a lube shop so they would know in the pit what filters to use.
-Mike Owen-
Old 12-01-2011, 01:46 AM   #19
ls1nova71
ls1nova71's Avatar
Hard to say what the 5.3 means, could have just had the transmission changed with one that was originally behind a 5.3, but that's just a guess. You can take a.spark plug.out and with a flashlight and a mirror look at the top of the piston to see if its flat or not if you're still in doubt if it's a LQ9 or LQ4. If you suspect the engine has been replaced with a 5.3 you could take the alternator bracket off and look behind it for a cast in 6.0 or 5.3/4.8. Also the original head gaskets have a little tab that sticks out of the side that would say 6.0 on it. But I would suspect that it still has the original engine in itif it was a rebuilt vehicle, it probably wasn't all that badly messed up when stolen, but the insurance company probably just wrote it off as a total loss to make things easy.
Old 12-01-2011, 01:50 AM   #20
ls1nova71
ls1nova71's Avatar
Vintage Windmills, an LS9 is an aluminum block, but I think you were thinking LQ9? In which case, no, they are a cast iron truck block.
Old 12-01-2011, 02:19 AM   #21
sleepertruck72
sleepertruck72's Avatar
Assuming you had to smog the truck when you purchased it, what was the engine size indicated on the vehicle inspection report ? If the emissions label is present on the air filter box or underhood somewhere compare the vacuum hose routing as best as you can to see if it matches. The engine size should show on there as well... Hope this helps
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 12-01-2011, 03:16 AM   #22
5150.4.67
If the number on the heads is 317, its a 6.0.
5150.4.67 is offline   Reply With Quote
