Old 11-30-2011, 02:46 PM   #1
Dustin07
Stirrer of the Pot
throttle hookup
my '62 had a throttle cable (schucks style) and my '61 has a mechanical lever, but I don't have the rest of the pieces to connect it to the carb. can I see some examples of how this is maybe 'supposed' to be setup? lol for now to get it running, I've created a make-shift solution using the old throttle line but I don't think its a good idea.
Dustin07 is offline   Reply With Quote
Old 11-30-2011, 03:44 PM   #2
1963c-10
1963c-10's Avatar
Re: throttle hookup
inline 6 or v8
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-30-2011, 03:47 PM   #3
Dustin07
Stirrer of the Pot
Re: throttle hookup
sorry 350 sbc
Old 11-30-2011, 06:34 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Re: throttle hookup
Not sure which way you're looking to go, but for the mechanical setup this thread may be of some value:
http://67-72chevytrucks.com/vboard/s...rottle+linkage
Old 11-30-2011, 08:21 PM   #5
samuellg1977
samuellg1977's Avatar
Re: throttle hookup
Here is the one i made for about $8 from True Value hardware. It works great. Just some food for thought. I have since Z'd the rod for a cleaner look and replaced the threaded end with and put heims on both ends. I can get a pic of it installed if you want it.
Sam
samuellg1977 is offline   Reply With Quote
Old 11-30-2011, 09:57 PM   #6
Dustin07
Stirrer of the Pot
Re: throttle hookup
perfect idea, thanks bro. good creativity
Old 11-30-2011, 10:37 PM   #7
samuellg1977
Re: throttle hookup
Like i said before, i had to "adjust" it to clear my trans cable bracket. Here is an updated pic to show how it is installed now. The threaded end with the nut on it before kept loosening up, so i added the heim on the other end to make sure it was tight and i haven't touched it since. Anyway, here is the pic.
Sam
