Old 04-20-2003, 11:32 PM   #1
JesseB
Body Lift and 33 inch tires
I'm thinking about putting a 2" body lift on my '71 Chevy truck and was wondering if that was sufficient to accomodate size 33 tires and what problems may I encounter when doing this?
Can anyone give me any pointers on what to pay attention to when doing this? Your response is appreciated.
JesseB is offline   Reply With Quote
Old 04-21-2003, 01:55 PM   #2
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
should fit with no problems. when installing the lift, do one side at a time and leave the bolts loose on the other side. then you don't have to realign the body and cab. good luck!
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 04-23-2003, 10:47 PM   #3
JesseB
Thanks YellowGMC! I was also told that with the 2" body lift, I would have to do a lot of modification with the brake lines, radiator shroud, etc... sounds more difficult with everyone I talk to...any truth?
Old 04-24-2003, 07:53 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I believe with a body lift you do end up having to tweak more items than with a suspension lift. In addition to what you mention you have steering, fuel line from cab to frame rail don't forget gaps betweenbumpers and body, e-brake cable, clutch linkeage, throtle linkeage, Suspension lift slightly more but in my opinion more straight forward and for 2" really nothing else to mess with but adjust drag link.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-24-2003, 09:10 PM   #5
JesseB
Thanks again! Another question, I'm thinking of doing the body lift myself to save money, but some people I know said I can have a local off-road shop install it with all the modifications for approximately $300. Does that sound reasonable for the amount of work involved? Thanks for your response.
Old 04-25-2003, 05:10 AM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
That's about what my neighbor paid for his body lift on his toyota.
Old 04-29-2003, 12:53 AM   #7
Solarus1981
I have a stock, worn out 2wd that clears 32x11.5x15 coopers. 33's should be easy.
'67 LWB C-10, 406 cid th350, dunno what rear end
Looking to rent a house in Puget Sound area, anyone have one?
Solarus1981 is offline   Reply With Quote
Old 05-10-2003, 02:22 AM   #8
chevy69er
Body lift
Im running 33's on my 69.All I did was get 1 1/2" lift springs from Rancho and i left the rear stock.They fit great and it looks awesome.
1969 C-20,383 stroker,sm465,custom long travel front suspension,4 wheel disc brakes,35" pro comps...mods under way include: 4x4 conversion,and custom bumpers.future mods include: gear vendors od unit,and relocation of fuel cell.
chevy69er is offline   Reply With Quote
Old 05-10-2003, 04:01 PM   #9
JesseB
How 'bout pics? I too installed heavy duty springs- decided against the 2" lift right now, and the '33 fit great. Looks like a 4x4.
Old 05-22-2003, 04:55 PM   #10
Tobes85K5
For the money you are going to spend on the body lift and installation, you should go ahead and get a 2 1/2 in. suspension lift. It is very easy to put on and it will improve your ride.
Tobes85K5 is offline   Reply With Quote
