Old 11-30-2011, 07:11 PM   #1
weider1717
Cleaned IAC today, but did I harm the IAC?
I took the IAC off and cleaned it today it wasn't dirty at all really. Anyway while I had it out I pushed on the tip of the plunger and it went in some but didn't pop back out. By doing that did I hurt the iac in anyway?
weider1717 is offline   Reply With Quote
Old 12-01-2011, 02:50 AM   #2
Desert1957
Desert1957's Avatar
Re: Cleaned IAC today, but did I harm the IAC?
No, normally it will not hurt it. The IAC is just a motor, it has a little plunger that is controlled by the ECM. Basically a controlled vacuum leak with the engine running.
after re installing cycle the key and leave it on, it will go through its motions and reset itself.
Desert
Desert1957 is offline   Reply With Quote
