Old 04-20-2003, 11:55 PM   #1
LeRoy
Registered truck nut
LeRoy's Avatar
1/2 ton Axle shaft, swap Question?
Is the cut-off 1970 for doing this? What I want to do is. Swap the axle shafts from a 72 Coil sprung, 5 lug, rearend into a 1970 Leaf sprung, 6 lug, factory posi, rearend. Thoughts?
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 04-21-2003, 12:07 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You should be good asuming you have a 70 rear and it wasn't swapped out at some point in its life.
70 was the only year 6 lug rear that is the same width as the later 5 lug.
Don't forget to grab the drums from the donor truck too.
Old 04-21-2003, 12:26 AM   #3
LeRoy
LeRoy's Avatar
Thanks. This 6 lug is out of a 4x4. That shouldn't be a problem, right?
Old 04-21-2003, 11:45 AM   #4
LeRoy
LeRoy's Avatar
ttt
Old 04-22-2003, 12:06 AM   #5
Longhorn Man
Hmmm, no idea.
I know the front track width on a 4X4 is wider...not sure bout the rear though.
Old 04-22-2003, 01:19 AM   #6
LeRoy
LeRoy's Avatar
Ya, I'm pretty sure that the leaf spring mounts are space the same width apart. Guess I'll just pull the axles out of the 70 and measure. Thanks again
Old 04-22-2003, 07:47 AM   #7
JimKshortstep4x4
Talking
Leroy,
You should not have trouble with the axle swap, but I was curious as to whether or not the 4x4 rear end is installed into your truck or not.
The spring perches are different between the 4x4 and the 2 wheel drive leaf spring trucks.
Jim
