Old 11-30-2011, 10:07 PM   #1
gag1025
Fuel Line Cutoff Valve
Where would I find a 3/8" gas line cutoff valve to make it easy to cut the gas supply off when I need to change out the inline fuel filter.
gag1025 is offline   Reply With Quote
Old 11-30-2011, 11:33 PM   #2
solidaxel
solidaxel's Avatar
Re: Fuel Line Cutoff Valve
I found a 3/8 Ball Valve at H F. and soldered into my 3/8 feed line before the filter
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-01-2011, 12:36 AM   #3
gag1025
Thanks for the reply. What is HF?
Old 12-01-2011, 12:53 AM   #4
mixermike
mixermike's Avatar
i assume HARBOR FREIGHT. i used a ball valve as a theft deterrent in one of my cars. with valve in closed position car would start and run for about 2 blocks and run out of fuel. thief would think WTF?
mixermike is offline   Reply With Quote
Old 12-01-2011, 09:35 AM   #5
gag1025
HF = Harbor freight. Makes sence. Can you use a valve made for water on a gasoline line? I did not know if the gasoline would deteriorate the imnternal parts especially if the valve is not all brass.
Old 12-01-2011, 12:19 PM   #6
gag1025
I had to go to my localy owned parts store and found a cutoff valve made specifically for the purpose I intend to use it for. None of the chain stores had what I needed (Advance Auto, NAPA, Carquest, AutoZone, O'Reilly's, etc).
