12-01-2011, 01:15 AM | #1 |
6 cylinder tach
Is there such a thing? My cousin is building a highly optioned 6 cylinder truck. He has all the pieces but neither of us has ever seen a 6 cylinder truck with a tach, even though we have both owned many 67-72s, and been around these trucks since they were new. He wants to know if he should continue his search.
98 GMC Sierra Ex Cab, cowl hood, Euro LED lights, 30 bar billet, Whipple Supercharged 350 Vortec: Forged flattops, E-Tec aluminum heads, Comp Cam, Scat crank and rods, Granatelli Mass air flow, Headers, Flowmaster exhaust , Complete MSD Ignition, Custom Tuning, intake spacer , ported throttle body, AC Delco port injection upgrade, Roller Rockers, Power Pulleys. Gear Vendors Overdrive. Soon to hit a dyno. 2/4 drop(for now). 95 Chevy S-10 Ex Cab 4.3 5 Speed 2/3 drop, Euro lights, billet grill, More to come. The Daily Driver |
12-01-2011, 01:17 AM | #2 |
Re: 6 cylinder tach
Yes there is and there was even one for sale in the forum classifides a while back, and I think it also had speed warning with it.
Bud |
12-01-2011, 01:19 AM | #3 |
Roadtrip!
Re: 6 cylinder tach
They are out there. Not very common however.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
12-01-2011, 01:36 AM | #4 |
Re: 6 cylinder tach
Here are some links that will help you ID a tach if you find one. I only remember ever seeing one and it was in a C40.
http://67-72chevytrucks.com/vboard/s...d.php?t=482997 http://67-72chevytrucks.com/vboard/s...d.php?t=471682 http://67-72chevytrucks.com/vboard/s...d.php?t=405334
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
12-01-2011, 01:45 AM | #5 |
Member #1049
Re: 6 cylinder tach
Yes, They are out there. I have been playing with these trucks for the better part of 30 years and I have only run across three 6 cylinder tachs.
Here is the part number to help you out......#6468321 |
12-01-2011, 10:07 AM | #6 |
Re: 6 cylinder tach
alot of your old Sun tachs are multi cylinder just pull it apart and ther is a switch inside that is marked 4-6-8 and you just switch it to whatever you have .
1965 Chevy Suburban 2003 Chevrolet S10 2011 Harley Streetglide |
12-01-2011, 12:41 PM | #7 |
Re: 6 cylinder tach
Hey, thanks for the quick info guys. I will keep my eyes open on the parts boards for one.
1968ratrod, thanks, but this is a resto, so looking for a factory tach. FYI, most aftermarket tachs have either a switch or wires you can cut for multi-cylinder use
12-01-2011, 08:58 PM | #8 |
Cool Truck
Re: 6 cylinder tach
I wouldn't mind having one myself
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
12-01-2011, 09:06 PM | #9 |
Re: 6 cylinder tach
I have seen a few in gmc v-6 trucks & bigger series 40 and up. My 68 panel has one out of gmc v-6. Rare when equiped in 6 cly chevy.
02-13-2012, 07:34 PM | #10 |
Re: 6 cylinder tach
i would also like too find a 6 cylinder tach for are trucks , also would one from mid 60s too early 70s chevy/gm cars one would fit in are trucks
02-13-2012, 08:17 PM | #11 |
Re: 6 cylinder tach
A 69 3/4 ton chevy 4x4 that is for sale locally has a factory 292 6 cyl in it and it has the factory tach. Truck was bought new by a rural fire dept and they later sold it to a friend of the guy that is selling it. I was thinking of buying it but it has no title and his friend tried getting the title from the fire dept but said they didn't think they had ever titled it or if they did, they have no clue where it is at. Truck only has 13,000 original miles but is in kind of rough shape from sitting outside for years and it does not run.
Wayne |
02-13-2012, 10:32 PM | #12 |
Re: 6 cylinder tach
are the 6cyl tachs the ones that go to 8k rpm? I saw one of those the other day and about fell over..lol
02-13-2012, 11:24 PM | #13 |
Re: 6 cylinder tach
70monte most likey want a arm and a leg for but like to see a picture or 2 if you can
02-14-2012, 12:17 AM | #14 |
Roadtrip!
Re: 6 cylinder tach
6 cyl tachs and V-8 tachs both go to 5K rpms. The mechanical driven diesel tachs went to 4K. The 8K ones are aftermarket or a camaro conversion.
02-14-2012, 12:27 AM | #15 |
Re: 6 cylinder tach
He wants a $1,000 for the truck. It would make a good parts truck because it has all of the heavy duty 4x4 drivetrain. He said the bed is rusted out from having the water tank back there. There are dents on the passenger side and the rockers and cab corners are rusted. He didn't think the floor boards were too bad. Truck sits up a little high like it has a lift on it but he said it's not. It has a 14 leaf rear spring and the front probably has a bunch too. The front frame horns are gone from whatever they had mounted on the front of the truck at one time. Cab has the factory cab lights on it. I'm still thinking of buying it for future use.
Here are some pics of the truck and tach dash. Wayne |
02-14-2012, 01:18 AM | #16 |
"GO DAWGS"
Re: 6 cylinder tach
Eric I think he is refering to the new aftermarket 8k tach dash set in this link. http://67-72chevytrucks.com/vboard/s...d.php?t=455559 As far as the 6 cyl. tachs go I have been fooling with these trucks for 25 years and have only run across two.
PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
02-14-2012, 02:42 PM | #17 |
Re: 6 cylinder tach
I believe Kevin "Kev's Classic's" has one he's not using.
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
02-14-2012, 02:58 PM | #18 |
C/10 junkie
Re: 6 cylinder tach
I want one as well
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
02-14-2012, 05:57 PM | #19 |
Re: 6 cylinder tach
Could you use something like THIS?
Here is a thread on the subject. http://www.jalopyjournal.com/forum/s...ad.php?t=96494 |
02-14-2012, 07:53 PM | #20 |
67-72=-5
Re: 6 cylinder tach
02-14-2012, 09:26 PM | #21 |
Re: 6 cylinder tach
Trying not to high jack this post , trying to find out somthing , too much stuff what about this also would a 6 cylinder tach from mid 60s too early 70s chevy/gm cars one would fit in are trucks
02-14-2012, 09:28 PM | #22 |
Re: 6 cylinder tach
70monte some one should get the truck and part it out on the parts board
02-14-2012, 09:41 PM | #23 |
Roadtrip!
Re: 6 cylinder tach
I am sure there are other tachs that would fit with some work, but if you want original you will have to hope you get lucky and find one. I have only seen a handful of original 6 cyl tachs in my day.
02-14-2012, 09:47 PM | #24 |
67-72 parts collector,…
Re: 6 cylinder tach
too much stuff,... what's the going price for a 6-cylinder tach?
02-14-2012, 10:13 PM | #25 |
Roadtrip!
Re: 6 cylinder tach
Surprisingly the last few i have seen were very reasonable. Sometimes unbelieveable. (e-bay 140659700622) You just so seldom see them, but it is a limited market also. I would say they bring similar money to a nice v-8 tach normally.
