Old 12-01-2011, 07:31 AM   #1
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Question Any good tips on how to seal a windshield gasket?
I had a new windshield installed and it leaked on both sides. Took it back and they put more sealer in it. Still leaks! (not as bad) I think they are using the sealer sparingly by the looks of things.
Rather than go through this ordeal again, I thought I'd just seal the dang thing myself. (that's how things usually end up getting done right!)
Looking for the best way to get sealer in both front and back side of the gasket? Inject it in somehow? Use some kind of a tool to pry the gasket away? Other ideas?
Thanks,
Bob
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 12-01-2011, 08:01 AM   #2
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Re: Any good tips on how to seal a windshield gasket?
Hello Bob,
You're not alone, :
http://67-72chevytrucks.com/vboard/s...d.php?t=492910
There are others but this is not uncommon.
Good Luck
TobyArnot is offline   Reply With Quote
Old 12-01-2011, 09:38 AM   #3
RenoKeene
Florida Edition
RenoKeene's Avatar
I wish someone would come up with a better setup than what we are getting. I'm trying to build a show truck (at least in my eyes) and this is killing my project. Imagine walking up to what you think is a beautiful piece of work only to look inside and see a wrinked up POS gasket. If mine doesn't get straightened out soon I'm going blow a gasket!
Sorry for the rant....
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 12-01-2011, 10:11 AM   #4
JimKshortstep4x4
Bob,
From my experience most of the leaks are in the top corners of the seal where the seal meets the 90 degree corner. I would suggest sealing the corner and about 4" down on each side I like the black ureathane like the roofing guys use.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-01-2011, 05:43 PM   #5
fast_dev
fast_dev's Avatar
bob, we have windshield urethane here and im told klines has a primer solution to swab on the pinchweld to help the urethane seal. or you could contact kurtz brothers glass in tamaqua they will come to you and fix it and are very good and very reasonably priced. 570-225-6209
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
