Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-01-2011, 10:49 AM   #1
prostreet1967
prostreet1967's Avatar
cage question
can someone tell me if this is legal. would like to stay below window but would hate to one day be fast enough to need to get certified and have to redo truck again. thanks
prostreet1967 is offline   Reply With Quote
Old 12-01-2011, 12:28 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: cage question
I cannot see inside the cab, but it is not legal for 10.00 ET, or quicker. Rearward bars from the main hoop have to be within 5" from the top of the main hoop, if you use tubing 1.5" diameter, or larger.
If you are planning on running at a NHRA track, be sure to invest in a rulebook.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-01-2011, 12:44 PM   #3
PGSigns
PGSigns's Avatar
Re: cage question
You can get away with out the bars going to the back if the drivers area is built to the left hand steer roadster spec. What you end up with is a funny car cage in it and some more bars on the inside of the cab. A rule book is a good idea any time you are building a cage/ full chassis. Always decide how fast you may ever want to go in the vehicle and build to that spec. As you get into the faster classes the certifications change and the cage must meet an SFI spec.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-01-2011, 12:56 PM   #4
vin63
vin63's Avatar
Re: cage question
Jimmy
Not for quicker than 10.00 ET. For 9.99 ET to 7.50 ET, the cage has to meet SFI 15.1E through 25.4 rating with a full SFI 2.4B through 2.7A dragster cage or SFI 10.2 through 10.4 roadster cage configurations that is attached to the 4-pt cage (window bar).
Old 12-01-2011, 02:36 PM   #5
blackedoutharley
Re: cage question
What Vin63 said.....
blackedoutharley is offline   Reply With Quote
Old 12-02-2011, 04:57 AM   #6
BigDan3131
BigDan3131's Avatar
Re: cage question
You have to ask yourself a simple question...Is my life worth having a proper cage to save me?. I know guys who run the below window style who race their trucks just once to see how fast it is. But if you get the bug and your time shows promise a Lexan window isn't such a big deal.
BigDan3131 is offline   Reply With Quote
Old 12-04-2011, 11:02 AM   #7
moggey01
Re: cage question
Actually Tom Yancer had a Pro Stock truck that was built with the bars below the window. It was certified to run 7s, and he had the funny car cage in it.
moggey01 is offline   Reply With Quote
Old 12-04-2011, 12:33 PM   #8
Marv D
Registered Truck Offender
Marv D's Avatar
Re: cage question
My 66 is built very similar and I can tell you Division 7 NHRA tech agrees with Vin63 and PGsigns,,,, Except that they will not allow anything 11.49 and quicker without the back bars, OR a funny car cage. Inside, outside, they don't care,, the tubes have to be in place. The rear supports must attach to the main hoop within 5" of the top of the hoop for a 'bar" or 12point "cage".
The 9.99 SFI chassis sticker get's real sticky and like metioned, There are a number of trucks with the Roadster / funny car cage 'inside' the cabin that meets the spec somehow. A couple of Yancers old truck chassis' are running in the sportsman classes around here in Az and Moggey is right,,, you can't see any back bars from the outside.
But to the point of the original question,,, I'm suspecting this is a brand new build, or a pro-street show truck / driver (and a VERY nice job BTW). I see no ice tank for a intercooler, the tire dressing on the MT Sprotsman tires, no rock dents in the tubs,,,,,, I'm guessing (as always), but were not looking at a sub 11 second ride are we? I think the bar / back bars are going to be a issue for the 10.01 to 11.49 ET range
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 12-04-2011, 02:29 PM   #9
vin63
vin63's Avatar
Re: cage question
Originally Posted by Marv D View Post
...The 9.99 SFI chassis sticker get's real sticky and like metioned, There are a number of trucks with the Roadster / funny car cage 'inside' the cabin that meets the spec somehow. A couple of Yancers old truck chassis' are running in the sportsman classes around here in Az and Moggey is right,,, you can't see any back bars from the outside...
Yep, those chassises are built to the roadster spec as I mentioned earlier that's outlined in the rulebook...essentially a roadster roll cage (left hand drive) attached and built within a cage inside the cab. Similar to the roll cage of my funny car chassis (center steer), I do not have rearward bars to the back of the chassis structure.
So, if prostreet1967 is going to build a roll cage for his truck, I'm under the assumption that he plans to go quick enough to warrant it. If not, building a roll cage is not a good idea.
Old 12-04-2011, 06:41 PM   #10
moggey01
Re: cage question
You could probably do some creative bending and get the tubes within 5 inches and still make it below the window. I dont want the bars on my truck to show either, and I dont want a funny car cage for a street driven truck. LOL Ill just have to see what they will allow.
Old 12-04-2011, 09:44 PM   #11
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: cage question
Not to high jack but HMP was pretty leaniante (nice clean passes). RPR not so much .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-05-2011, 11:53 AM   #12
vin63
vin63's Avatar
Re: cage question
The rearward bars from the main hoop must be a minimum of 30 degree angle from vertical and mounted to the rear frame structure. This is why if you go the route of building a cage for safety at the required ET and MPH, it's important to ensure the cage indeed protects you as opposed to looks. Otherwise, an inadequatly built cage can be quite dangerous to the occupant(s).
Old 12-16-2011, 09:04 PM   #13
prostreet1967
Re: cage question
hey what are yal using for solid mounts.
Old 12-17-2011, 11:11 AM   #14
Marv D
Marv D's Avatar
Re: cage question
as in solid engine mounts? They stress the side of the block in a high HP application and are typically used only to help control lateral movement.
Motor plates. Aluminum front plate and steel mid plate, poly mount on the rear of the trans is the typical.
Old 12-18-2011, 12:33 AM   #15
Captainfab
60-66 Nut
Re: cage question
Depending on what style mounts you are running, I still have these for sale
http://www.67-72chevytrucks.com/vboa...d.php?t=478578
Old 12-18-2011, 02:39 AM   #16
prostreet1967
Re: cage question
was talking about body mounts sorry lol. gonna do cage and back half in next couple weeks. i heard im good with plates to cab but gonna tie into to rear frame so i wanted it to be stout as possible
Old 12-18-2011, 10:18 AM   #17
Marv D
Marv D's Avatar
Re: cage question
My cab floats on the stock rubber mounts,, I have seen builds like Regan's that isn't, but I took the rule book to heart and tied the cage to the frame with outriggers under the cab. With a backhalf, I'd think seriously about how you tie it all together. Your cutting the frame in half, then supporting it with the flimsy cab floor. Even with solid cab mounts I think your gonna see things flexing and breaking if it's making big power and hooking up.
Old 12-19-2011, 02:37 PM   #18
prostreet1967
Re: cage question
u have any pics of ur outriggers? ive seen some posted that dont look good. my truck is already back halfed but i havent tied cage to frame. going to redo backhalf in round tube so figured now would be the time to do it right.
Old 12-19-2011, 03:18 PM   #19
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: cage question
Here is one of mine off my old blue luv . To the right is the rocker of the truck cab and to the left is the frame rail , behind it is the cab mount . It is dirty in this picture . This is also mild steel and not chrome moly . You can see the main hoop welded to the top of the out rigger so it can be fully welded . then the main hoop was raised into place with outrigger welded to it and it is then welded on 3 sides . The top of the outrigger is welded when the the hole is cut for the next bar to the top of the frame .The next bar in the cab are Kickers that run from the crotch of the seat belt bar and main hoop , then angle inward to the top of the frame rail to trianglulate tha connection . Clear as mud ?
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-19-2011, 03:52 PM   #20
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: cage question
Here is a good illistration . The proportion of the bars are probably not to scale ,, but it gives you an idea of the triangle .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-19-2011, 06:01 PM   #21
bcdeutsch731
bcdeutsch731's Avatar
Re: cage question
Here are some I have found.
1969 C10, 2005 LLY Duramax, Wagler Competition built motor, Bullseye Power triple Turbo's, Rossler th400, Neal Chance Racing Converter, Danville Performance tunning.
8.3@168mph 1700+ HP
bcdeutsch731 is offline   Reply With Quote
Old 12-19-2011, 11:03 PM   #22
raceman6135
Dino burner
raceman6135's Avatar
Re: cage question
Just so that I understand the situation: you have a truck that was originally a full-frame truck, and someone has told you that you can just mount part of the cage to plates bolted to the floor?
I don't believe any sanctioning body, and for sure SFI, won't allow plates to hold any part of the cage unless it's a factory unitized body (aka "unibody") type of car.
As already discussed, outriggers are required, and the roll cage tubing must pass through the sheet metal of the floor.
raceman6135 is offline   Reply With Quote
Old 12-20-2011, 10:45 PM   #23
kpeztruck
kpeztruck's Avatar
Re: cage question
I will have to try and get some photos of my cage set up. My chassis man, Steve Tucker @ Southeast Hot Rods, cut throught the florr just inside of the inner rockers, and sank a
2x3 piece into the floor, and cut the cab floor supports out to accomodate the 2x3. He then attached the "rocker 2x3" to the frame rails with round chromoly as per sfi specs. Keep in mind that the structure must from a complete box under the floor. ( outer 2x3 to outside of framerail, inside frame to opposite inside frame to other 2x3. This must be done at rear of cab with main hoop, and front of cab with the front legs as well). I hope my word picture is clearer than mud. lol Paul
kpeztruck is offline   Reply With Quote
Old 12-21-2011, 07:52 AM   #24
bcdeutsch731
Re: cage question
I would like to see that if you could get some pictures.
Brett
8.3@168mph 1700+ HP
Old 12-22-2011, 01:26 AM   #25
prostreet1967
Re: cage question
So your saying not only run 2x3 square for outriggers front n back then tie them together but then I gotta connect from drivers side inner frame to passenger side inner frame to form square!
Raceman, no what I'm saying is my truck already has been back halfed n has cage. Cage goes to plates on floor n doesn't have down bars to rear. I'm bout to redo back half n cage just trying to b clear before I start
