Old 12-01-2011, 04:44 PM   #1
redbaron69
redbaron69's Avatar
sway bar question
i am replacing my front crossmember in my 69 with a 73 crossmember.(for the disc swap). my 69 has the factory sway bar, will it work on the 73 crossmember? thanks
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 12-01-2011, 05:13 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: sway bar question
Sway bar From 73+ will fit (with all the squarebody brakcets) you'll have to drill a rivit somehwere tho
John
1999 Toyota Tacoma 4x4
Old 12-01-2011, 05:19 PM   #3
redbaron69
redbaron69's Avatar
thanks for the reply old blue. looks like another junk yard trip.
Old 12-02-2011, 09:58 AM   #4
summerj
I just installed one on my 65 that i pulled from an 86 3/4 ton from salvage yard. 1" Bar. bought 4 Moog blue bushings for $20 at Advanced Auto. Bolted it right to the frame-no brackets. had to use some ratchet straps and jack to compress bar a little bit. Drilled out the 2 rivits on rad support. (1 at a time). You will need to drill two additional holes into frame for top mounts. Used the existing holes on the lower A arms. took about 2 hours total. I am running the 2.5 drop spindles. cost less than 50 bucks.
summerj is offline   Reply With Quote
