Old 12-01-2011, 05:43 PM   #1
Hazieview
Building Dreams out of Dimes!
First time wiring an engine. Please help!!!
Ok guys I have an '81 Chevy shortbed with
c.i. SB400.
No A.C.
One wire alternator
High torque starter.
I purchased a stock replacement engine harness for my truck. I got the harness plugged into the fuse box through the fire wall and the bolt in. I plugged the next two plugs into the windshield wiped motor. Now where in the heck do the rest of the wires go? Haha!
1. One really Long thin pink wire with a round rubber cover.
2. One heavy red wire about one foot long.
3. Two red wires spliced into one single black wire
Further down....
4. One long thin green wire with a white plastic connector.
5. Three thin wires (pink, light blue, dark blue,) leading to a big black plastic plug with a side snap.
6. Fat pink wire with white plastic connector.
7. Thin light brown wire with a round rubber connector.
Further down...
8. A light blue wire with a plastic grey connector.
9. Two wires (one brown, one red) with a white plastic connector.
10. One red wire with a rubber boot.
Further down...
11. One purple wire
12. Two red wires spliced into a black wire.
13. One red wire spliced into a brown wire.
* the black and brown wire then splice together at a connector.
Please help me not burn down everything! The battery is disconnected for now! Thanks!
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 12-01-2011, 08:00 PM   #2
Jonboy
Slots go on anything!
Re: First time wiring an engine. Please help!!!
Post up some pics of the plugs you are having trouble with. A lot of time the connector shape is a giveaway.
1974 Jimmy- 5.3/4L80e/NP241
Old 12-01-2011, 08:54 PM   #3
Hotrodrobert
You must get a wiring diagram!!!!!!!!!!!!!!
74 Longbed
76 Shortbed
87 Shortbed
66 Corvair Turbo
62 Chevy II Turbo 6
Hotrodrobert is offline   Reply With Quote
Old 12-01-2011, 10:30 PM   #4
Hazieview
All the wiring diagrams I have found make my head do this
SB400 350th
Old 12-02-2011, 10:20 AM   #5
Hotrodrobert
You are in trouble. The best thing for you to do now is try to find another similar truck and see where the wires go on it. If you can't do that, post again and I will get a diagram and do what I can to help.
74 Longbed
76 Shortbed
87 Shortbed
66 Corvair Turbo
62 Chevy II Turbo 6
Old 12-02-2011, 11:24 AM   #6
Pop's C-10
Pop's C-10's Avatar
I know tha feeling
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 12-02-2011, 12:01 PM   #7
njlimbaugh
Let me toss in some general information here for those thinking about rewiring. I've rewired a pickup and 2 cars over the last several years without buying a prebuilt harness. You will need a good wire cutter/stripper, several rolls of wire in as many colors as you can find, for newer trucks mostly 16 and 18 gauge. Terminals will come later. Step one: open all harnesses so you have access to each individual wire. If there are unused wires in the harness, check both ends to be sure then throw them out. If not certain leave them in for now. Make a list of connector types used on your truck and the gauge of those wires. The cutter can be used to determine wire gauge. Pick a wire, be sure you know which end is connected to what, make a new wire to match with the correct terminals, put that wire in and toss out the old one. Repeat as necessary. It ain't that hard, guys, and will save you a boatload of money.
njlimbaugh is offline   Reply With Quote
Old 12-02-2011, 09:44 PM   #8
Hazieview
Thanks for the info but I have already purchased a stock replacement harness.
I'm trying to determine where the wires go on a stock replacement setup. My other harness had already been hacked up by someone with a set of wire cutters and electrical tape. I know how to use wire cutters and connectors I just need help with where the wires need to go. That is the hard part.
If anyone can give me a step by step or a good wiring schematic I would greatly appreciate it.
Thanks!
SB400 350th
Old 12-02-2011, 11:43 PM   #9
Fixwhataintbroke
Enthusiast
Fixwhataintbroke's Avatar
I BELIEVE that 9 and 10 are for the alternator for a 3 wire setup
- Cole
1979 Chevy C30 w/ carb 454.
1992 Chevy K1500 w/ tbi 350. *Sold*
1997 Dodge Ram 1500 w/ Magnum 360 *Sold*
"Good judgment comes from experience. Experience comes from poor judgment." - George Washington
Fixwhataintbroke is offline   Reply With Quote
Old 12-02-2011, 11:51 PM   #10
Fixwhataintbroke
Enthusiast
http://www.schematicsunlimited.com/d...ng-diagram.pdf
- Cole
Old 12-04-2011, 12:11 AM   #11
Fixwhataintbroke
Enthusiast
Sorry for triple posting but my guess is that 5 is for distributor..but the diagram only shows 1 wire, a pink wire, going to distributor B+ terminal, 8 perhaps choke, and purple wire perhaps Starter? Just judging from the diagram (same diagram as the Haynes repair manual)
- Cole
Old 12-05-2011, 11:59 PM   #12
Hazieview
See I'm really having trouble trying to convert that whole part. I need to get rid of the fuse block all together I think.
All I need is to run one wire from my alternator to the starter where the battery hooks to it. My problem is figuring out what wires to elminate from the factory harness.
I am also running and HEI so I need to figure that out too.
SB400 350th
Old 12-06-2011, 05:59 PM   #13
Fixwhataintbroke
Enthusiast
I'd plug 10 to the batt terminal on the alternator and leave 9 disconnected. Then once the engine is wired enough to fire, just check the voltage at the battery (assuming truck is at a high enough rpm). 5 should just plug right into the distributor cap
- Cole
Old 12-07-2011, 03:52 PM   #14
hopelessredneck
hopelessredneck's Avatar
Lightbulb Re: First time wiring an engine. Please help!!!
i dont know if this will help but it is for vary basic chevy engine harness
hopelessredneck is offline   Reply With Quote
Old 12-21-2011, 01:10 PM   #15
t5noel
This might help.
http://forum.73-87chevytrucks.com/sm...?topic=11766.0
t5noel is offline   Reply With Quote
Old 05-26-2013, 07:16 PM   #16
maxxxy
maxxxy's Avatar
Did you ever find a good diagram? I'm trying to wire up my 350 in my 81 that I converted to a serpentine setup, and I have no idea what wired go where. I am using the factory harness.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 05-27-2013, 11:42 AM   #17
hatzie
Moderator
hatzie's Avatar
Grab the 1980 GM Wiring diagrams (foldout pages) and the 1981 GM service manual (the 1981 wiring diagrams are in the back on 8.5x11 pages but are harder for me to follow than the big foldouts)
http://67-72chevytrucks.com/vboard/s...d.php?t=545416
The first few pages are a table of the GM circuit numbers with the corresponding colors and functions.
The bulkhead plug positions and other termination point pinouts are identified by GM Circuit Number in the big foldout pages.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
