Old 12-01-2011, 11:27 PM   #1
Fords72ChevyC10
Fuel tank craziness; can you identify this fuel tank?
I have a 72 Chevy C10 longbed. The PO shaved the gas cap and removed the tank from the cab. He then installed 2 tanks under the bed in front of the rear tires. There is one on each side of the truck. The tanks are designed to be filled up in the wheel well of the rear tire. I wish I had pictures to show you but I don't at this time.
My question is; is this a "legitamate" fuel tank or was this custom made. And if it is a custom tank what are some things I need to look for to make sure it is safe? Also the fuel guage is not reading so I have no idea how much fuel I have. Right now I don't see any wires or anything suggesting that a fuel sending unit is connected. I'm not even sure there is a place for one as I have not dropped it yet. Any ideas on this as well?
Thanks for the help.
A Soldier in need of help
Fords72ChevyC10 is offline   Reply With Quote
Old 12-28-2011, 09:02 PM   #2
Fords72ChevyC10
Re: Fuel tank craziness; can you identify this fuel tank?
Finally I have Pictures
Old 12-29-2011, 12:21 AM   #3
dfwright
dfwright's Avatar
saddle tanks were a common option back in the day. My truck had saddle tanks installed. Mine didn't have hookup for a guage. We'd just run one saddle tank till the truck started to run out of gas, switch to the second, then switch to the main tank, and fill up all of them when it got low. There was a three-way switch on the cab floor beside the driver seat.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 12-29-2011, 03:17 AM   #4
Fords72ChevyC10
So these are stock tanks?
Where did you fill it up at? These are designed to be filled up in the wheel well.
Thanks for the info
Old 12-29-2011, 02:24 PM   #5
RenoKeene
Florida Edition
RenoKeene's Avatar
I've seen pics of tanks that fillup at the wheel well but never seen one out of the truck. I have a Custom Camper with a saddle tank that has the filler that comes out of the bedside. They probably are safe if they are solid. Do you have any pics of the fuel line hookup underneath the bed and cab? If you don't like these tanks you could always put a blazer tank in the back...plenty of threads in here on how to do that.
Ft. Irwin....I spent some time there, and Camp Roberts, and Hunter Ligget, and........
Thanks for serving your country!
Us vets lov ya.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 12-29-2011, 04:09 PM   #6
Fords72ChevyC10
Thanks for the appreciation.
I have not taken any pictures of the fuel hose. Ill try and take some today.
I don't mind the tanks, now that I know they are legitimate. This was the tank that was not connected to anything, so i dropped it to get a better look at what I am working with. The other side is the same.
Eventually i would like to hook up both of them.
