Old 12-01-2011, 11:53 PM   #1
brickren
brickren's Avatar
Transfer case shift pattern
Hello. I have no decal to tell me hi or hi lock. All the way forward is hi and one back is hi lock. Is that correct? I have a 1968 K20 w 327 4 sp. Were there any other transfer cases used that would have a different shift pattern? Would someone be kind enough to take a good picture of their sticker? I would like to print it out and put it in the tuck. Thank you. Brian
1968 K 20 w/327 4bbl 4 sp
brickren is offline   Reply With Quote
Old 12-02-2011, 12:12 AM   #2
webfoot
Re: Transfer case shift pattern
This is how it is in a 71 np205:
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 12-02-2011, 12:24 AM   #3
jbclassix
Junk Yartist
jbclassix's Avatar
if you have the stock t-case in your truck, all the way forward is 2HI back once is 4HI back once is N and all the way back is 4LO. The T case in your truck should be the Rockwell T221. If it is the stock t-case, the shifter will be on the driverside of the transmission shifter. If your truck has been converted to a NP205, your shift pattern will be: all the way forward is 4LO one back is N once back is 2HI and all the way back is 4HI. GM switched to the NP205 mid 69 year.
here is a link to the decals but you cant see them very well... check out the 4x4 section of the board
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 12-02-2011, 06:08 AM   #4
brickren
brickren's Avatar
Hello. Your description tells me I have the I have the Rockwell T221. Thank you for the help. Brian
Old 12-27-2011, 02:49 PM   #5
aventur1
aventur1's Avatar
Oh cool on the shift knob, where can I buy one for the np205 pattern? I have a 68 4x4x but the newer np205, I checked the numbers on the plate. Right now I have the pattern that shows like 4 wheels and lines that connect.
aventur1 is offline   Reply With Quote
