Old 12-02-2011, 12:22 AM   #1
chewychevy67
seat belt questions
i have removed a few sets of 67 belts and was wondering if there should only be one plastic sleve on the inner latch lap belts like in the picture or one on each side? if only one what side does it go on? been years since i removed them and before digital cameras and i keep seeing sets for sale with only one of them. also when optioned with shoulders do the inner shoulder mounting plates go under the lap mounts so the plastic sleve can go on top? thanks for any help on this.
chewychevy67 is online now   Reply With Quote
Old 12-02-2011, 12:26 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: seat belt questions
Interesting point....Of all the 67's I have pulled, the drivers side outer belt (female end) has had the plastic sleeve. I have never pulled a set that has had plastic sleeves on both female belts.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 12-02-2011, 12:29 AM   #3
chewychevy67
so im not that crazy. i was sure mine only had one.
Old 12-02-2011, 12:30 AM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
Originally Posted by leddzepp View Post
Interesting point....Of all the 67's I have pulled, the drivers side inner belt (male end) has had the plastic sleeve. I have never pulled a set that has had plastic sleeves on both male belts.
I don't recall seeing the plastic sleeves on both sides either. Just the one...
Another question, did all 67s have the chrome, thin headed bolts?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-02-2011, 12:39 AM   #5
leddzepp
Moderator
leddzepp's Avatar
All the ones I have pulled have had the thin headed bolts, as they are a different thread than the 68-up. Incidentally, the 67 bolts are also the correct thread for the shoulder belts in all years.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 12-02-2011, 02:00 AM   #6
67chevy1series
67chevy1series's Avatar
yes! im not crazy either! now i dont have to look for 2 that have sleeves just so i can have a "normal set" .... i already do!
67chevy1series is offline   Reply With Quote
Old 12-02-2011, 09:43 AM   #7
chewychevy67
even the date tags were sewn in different spots cause of the sleve. one is lower without the sleve and the other is just above the top of it in this pic.
Old 12-02-2011, 09:45 AM   #8
chewychevy67
so do you think the shoulder belt anchor would mount under the sleve then on the driver side?
Old 12-02-2011, 09:50 AM   #9
RenoKeene
Florida Edition
RenoKeene's Avatar
Very good info here...
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
