Old 12-02-2011, 01:07 AM   #1
Meatman
Meatman's Avatar
Dana 60 rear spindle nuts
What does the Dana 60 rear in my 68 3/4 ton have for spindle nuts? Are they are regular nut or are they the six prong?
From what I have put together
Eaton HO52 and Corporate 14 bolts---six prong
Dana 60s--regular nut that is like 2 9/16"?
Is this correct? Just want to make sure I have the tool I will need when I do my brakes.
Daily-94 K2500 350 5spd extended cab longbox
Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack.
Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881
My 01 TA and 88 Formula hide in the garage. :-)
Meatman is offline   Reply With Quote
Old 12-02-2011, 11:53 PM   #2
Meatman
Meatman's Avatar
Re: Dana 60 rear spindle nuts
Anyone....
Old 12-03-2011, 02:27 PM   #3
Bustedup
Here is what I use, lot better than beating a tab over.
http://www.speedwaymotors.com/Wide-5...-Nut,3759.html
Bustedup is offline   Reply With Quote
Old 12-03-2011, 03:25 PM   #4
BCOWANWHEELS
They have double nuts (2) on each side. 2 9/16 i believe. I can check further on the size if you need me too !
Bob
p/s
you can switch them out also if you want a different style there interchangeable new to old styles. i change modern 14 bolt ff rears to old double nut styles, i think older is better personally.....
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
