12-02-2011, 10:31 AM | #1 |
454 with factory H.O. heads?
I recently picked up a 1980 Silverado 30 with the beefy 454. An old timer at work (who has a 427 and 455W30) asked me to pull the top of motor and check the ports to see if it was an H.O.by looking at the ports. If they were square than it was H.O. if it was oval than it was plain jane. Is this true? I mean..shouldn't this be coded out? Which cars and trucks was this option available. He also wants to give me an edelbrock tarantula for it too that he has no use for.....
I feel sorry for people who don't drink....because when they wake up in the morning, that's the best they're gonna feel all day long!---Frank Sinatra RIP [B]1972 Chevrolet K5 Blazer RIP 1986 GMC Sierra K3500 1TON, Long Box, V8350 RIP 1980 Chevy Silverado C30 Cab and Chassis, 454 TH400HD. RIP [B] 1995 Chevrolet Tahoe 2D [B] |
12-02-2011, 10:54 AM | #2 |
Re: 454 with factory H.O. heads?
The rectangular port heads were never available on a truck;you do not have to pull the intake ;just pull a valve cover;the rectangular port heads will have hi perf cast in.
The 1980 should have the peanut port small oval heads ...the trucks switched to the small oval ports about 1975 The square port heads were available from 1965 to 1972 cars with the 4 bolt main perf engines....possibly 73 on Corvette They were and still are available on crate engines ...and were used on marine engines until the end of Mark 4 production in the late 90s |
12-02-2011, 11:14 AM | #3 |
thx! Yes, he did mention the valve covers.
12-02-2011, 11:21 AM | #4 | |
12-02-2011, 12:32 PM | #5 |
Also, just because it has retangular port heads does not make it high perf motor.
More than 1 hot rodder has put retangular port heads on a stock short block only to wind up w/a dud of a motor. Not enough compression, rpm, or valve event timing & those heads won't perform as well as the smaller oval port heads.
12-03-2011, 12:29 AM | #6 |
Dino burner
The Edelbrock Tarantula intake manifold is a single plane, high RPM intake that is not suited to street driving. The rotated carburetor mounting pad can sometimes cause clearance problems and linkage issues, too, depending upon what you're trying to connect it to.
12-03-2011, 02:29 AM | #7 | |
I am reasonably sure the heads had hi perf cast in only if they were square ports The blocks had pass hiperf cat in behind the timing chain....even if they were only 2 bolt main |
12-03-2011, 02:50 AM | #8 | |
After about '77, you couldn't get a truck with anything but peanut port heads until the late 90's when the L29 came out. Save your time, unless your engine has been replaced with a performance engine, you'll have small port heads. Swap 'em out for large port heads with no other changes and you'll slow down. |
12-03-2011, 09:51 PM | #9 | |
Dino burner
And yes, HI-PERF PASS was cast into the timing cover area of pretty much every big block Chevrolet block (except the truck blocks, of course), regardless if they were 2-bolt or 4-bolt main blocks. But, if you already have the timing cover removed, you can look down to the front crankshaft main bearing and see if it's a 2-bolt or 4-bolt block |
12-04-2011, 10:59 AM | #10 |
Done lots of BBC. "HI PERF" was cast in the rectangular port heads only.
All 4 bolt main blocks had "HI PERF PASS" cast into the block above the bell housing area. Standard blocks did not have this. If you have a cast iron intake, it is almost certainly not rectangular port heads. If you have an aluminum intake that is no guarantee either. Cast intakes and intakes for oval ports often don't cover the upper corners of the rectangular ports so you can have big intake air leaks there. You can use rectangular port intakes on oval or peanut heads, but seldom will the other intakes work on rectangular heads.
74 Longbed 76 Shortbed 87 Shortbed 66 Corvair Turbo 62 Chevy II Turbo 6 |
12-04-2011, 01:48 PM | #11 |
If your gonna go with stock BB heads and have a nice built motor you want the the heads that end in 781 or 049.
12-05-2011, 12:00 AM | #12 |
My 83 C-30 has a Gm crate motor installed in it. It was a ambulance at one time and then it done a tour as a rescue truck for several years before I got it. It is a camper special and the rescue squad put in a new crate 454 in it about 1991. They told me that they got the special crate engine from GM what ever that ment. Also told me that it had steel crank and hiperformance heads. I figure it is just a crate motor but how can I find out what I have with out taking the intake off. Motor runs great and I don't want to touch it untill I need too. Thanks
The fleet 94 Chevy 4x4 reg cab 2018 Traverse (wifes car) 1977 SWB stepside 1949 Chevy truck |
12-05-2011, 08:11 AM | #13 |
cj, just pull a valve cover and post the casting numbers here. If it's a "performance" engine, they'll end in 188.
