12-02-2011, 02:11 PM | #1 |
Suburban Questions
What are things to look for when purchasing a suburban in this body style? Also what would be a fair proce for and average running driving burban with minimal rust (doors only from what I was told).
Is there an advantage to clam shell rather than barn doors? |
12-02-2011, 04:54 PM | #2 |
Re: Suburban Questions
rust. I paid $2500 for a running burb needing restoration.
12-02-2011, 06:19 PM | #3 |
Just here to tinker
$2500 is probably going to be about average for a runner with some rust. As for the rear doors, it is preference.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
12-02-2011, 06:52 PM | #4 |
Resistance is Futile
Make sure it has everything from the doors to the rear bumper. Nothing is made for burbs with the exception of some rubber pieces.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
12-02-2011, 07:09 PM | #5 | |
Posted via Mobile Device |
12-02-2011, 08:42 PM | #6 |
from the "B" pillar forward it is pretty well the same except the roof has a different crown to it and the mounting under the "B" is different and the long floor supports are different; the ones that run from frt to back.
ron |
12-02-2011, 08:46 PM | #7 |
doors are the same as trucks
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
12-02-2011, 11:11 PM | #8 |
65 suburban vortec 5.3 bagged
Make sure it has all the seats you want window latches rear bumper and all the rear doors and hardware for the rear doors are there and are in good usable condition those items are the hardest most expensive parts.
as far as rust check the roof and around the front windsheild i got my sub for 500 and it was just a roller with no seats (craigslist) Posted via Mobile Device |
12-03-2011, 02:55 AM | #9 |
A Suburban will likely cost more than a truck in similar shape, and rightly so, as they did not make anywhere near as many. If you can find a solid, rust free driver for less than 5 G's, I think you're doing ok. You could pay a bit less up front and then spend a couple years and a few thou trying to get it to what you should have bought to begin with. It's your choice. Beyond that range, more money should equate to fewer needs.
As for the back end, I personally never could figure why anyone would prefer barn doors over a clamshell. Gates extend your load area and if needed can be driven securely in the open position (as long as you don't mind being mildly asphyxiated). Also, tailgate picnics are fun ...not so with doors. Lastly, not all burbs had third seats. Check the number of rear sliding windows. Four sliders means it had three seats. Two sliders =no third seat. |
12-03-2011, 11:32 AM | #10 |
chevy only
pm erock he has a killer one that just got painted and at a great price
CHEVY ONLY... Nothin Else ! |
12-03-2011, 03:33 PM | #11 |
12-04-2011, 01:15 AM | #12 | |
60-66 Nut
The cargo doors (barn doors) allow a person easier access to items in the rear cargo area without having to climb onto the tailgate to reach them. I'm one of the few that like the cargo doors.
12-05-2011, 05:21 PM | #13 |
Thanks to Dino, looks like I am getting a burb. Out of all the things to look for listed this one does not have a rear bumper, has everything else though. Is there an alternate bumper that can be used for the rear?
12-05-2011, 06:41 PM | #14 | |
Any body done this? Or is there another difference that I did not catch? |
12-05-2011, 06:43 PM | #15 |
I've looked at them, came ot the same conclusion as you, seems to be the same bumper with different mounting holes, but have not tried it.
12-06-2011, 01:13 AM | #16 |
60-66 Nut
The Suburban/Panel rear bumpers are basically the same except for the mounting hole pattern. A guy could fill the mounting holes in a front bumper and drill and file square a set of new holes. But you would also have the dimpled area around the upper bolt holes to deal with.
12-06-2011, 01:41 AM | #17 | |
12-06-2011, 01:49 AM | #18 |
60-66 Nut
I guess I should have explained myself better. What I was referring to is that if you were to fill the upper holes on a front bumper, it will be difficult to finish the welded area since it is in the dimpled area.
12-06-2011, 01:52 AM | #19 |
Oh, yeah. True.
12-06-2011, 09:33 AM | #20 |
Thanks guys,
Looking at the pictures it seems one could probably fab up something to move the mounting holes on the frame to use the existing holes in the bumper. |
12-06-2011, 10:30 AM | #21 |
Or just buy mine for 50.00.
12-06-2011, 03:31 PM | #22 |
chevy only
12-06-2011, 03:33 PM | #23 |
chevy only
congrats on the sub !
