12-02-2011, 03:32 PM | #1 |
Carpeting
The PO installed a newer carpet, but unfortunately it is low quality and was for a high hump and I have the low one. Looking to put in new carpet.
Question for the masses... Do you prefer custom carpet from a good upholsterer or a pre-molded carpet kit? If you prefer kit and have experience with a kit you would recommend, I'd love to know who that is. Thank you.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
12-02-2011, 05:34 PM | #2 |
Re: Carpeting
In for opinions as well. i was looking at either stockinterior.com's carpet, or lmc's.
12-02-2011, 06:54 PM | #3 |
Re: Carpeting
Why do carpet at all, I installed sound insulation, then heat insulation, and ordered a full rubber mat that goes from the firewall to the back wall of the cab, I then installed a new stock rubber floor mat to keep the original look. It is quiet and easy to take care of. Kieth
http://kieth.smugmug.com/Trucks/66-G..._QRXTmdg-X2-LB |
12-03-2011, 12:53 AM | #4 | |
Re: Carpeting
12-03-2011, 01:13 AM | #5 |
One day...
Re: Carpeting
I use stockinteriors.com on all i do, always has been good stuff.
12-03-2011, 09:36 PM | #6 |
Re: Carpeting
Now that presents another quandary. Has anyone purchased the Cab Door Bottom carpet set? If so, I'd like to see pictures.
12-03-2011, 11:33 PM | #7 |
Re: Carpeting
Mine has some sort of black shagg carpet to go with the diamond tuck seats and visor that I bought it with (very 70's). That said, I prefer a premolded, loop style. Short, tight and easy to clean. I'm not sure about the door bottoms though. My Impala had that with the courtesy lights in them... now you have me thinking of another upgrade!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
12-04-2011, 02:08 AM | #8 |
Re: Carpeting
LMC carpet kit is nice. I have the black low bump setup. I'll see if I have a pic
X24 1964 chevy c10 step side 230ci straight six Auto power glide |
