Old 12-03-2011, 01:50 AM   #1
shiner2001
shiner2001's Avatar
Question New CD player, now blowing marker light fuse...any ideas?
I just changed CD players in my 90 Suburban today and after I did, I am blowing the fuse for my parking and tail lights when both they and the radio are turned on at the same time. I thought the 12v constant that I picked up behind the radio might be the culprit, so I changed power for my radio to a dedicated 12v constant on the fuse box (upper left corner), but the problem persists. After going through 3 fuses, I finally just took the radio out so I could get on with running my errands (which now included stopping to get more fuses). Once I got back home, I tried one more time, but this time (vehicle running), I turned on the radio and then the lights, but the fuse didn't blow. This time the radio just went off. I figure that might have something to do with my 12v switched power to the radio, so tomorrow I am going to pick that up from a different source (hopefully directly from the fuse block) and see if that solves the problem Does anyone else have any suggestions other than that as to what might be causing the problem or what a possible fix could be?
Thanks in advance!!
Derek
72 Chevy Cheyenne Super LWB 454 SS LS6
90 GMC Suburban V2500 350
64 Chevy El Camino 357
73 Jeep Wagoneer 360
78 Jeep Cherokee 360
79 Scout II 345
88 Jeep Wrangler 4.2L
91 Jeep Wrangler 4.3L
98 Lincoln Mark VIII 4.6L
01 GMC Yukon 5.3L
"If it's not broken, fix it 'till it is!"
shiner2001 is offline   Reply With Quote
Old 12-03-2011, 03:47 AM   #2
shiner2001
shiner2001's Avatar
Re: New CD player, now blowing marker light fuse...any ideas?
Went ahead and rewired the 12V switched power directly to an accessory terminal on the fusebox and immediately blew the marker light fuse when I turned on the lights with the radio on. Back to square one...
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 12-03-2011, 06:19 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
may want to check the power isn't the grey dash dimmer
you want the yellow
and check for a good ground
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-03-2011, 03:35 PM   #4
shiner2001
shiner2001's Avatar
I'm picking up both of my 12v powers from the fuse box now, next up is regrounding directly to the chassis to see if that helps.
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 12-07-2011, 04:46 AM   #5
shiner2001
shiner2001's Avatar
Oddly enough I had the dimmer wire as the ground, as that's how it tests with a meter if the lights are off. Grounded to the chassis and it's good to go.
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 12-07-2011, 08:13 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Cool
http://forum.73-87chevytrucks.com/sm...?topic=11766.0
this may help sort out the wires
John
