Old 12-03-2011, 02:26 AM   #1
ericjon262
1967 Tcase
I've heard several conflicting reports as to what transfer case the 1967-72 trucks used, and I'm looking at getting a 67 4x4so I'd like to know what I'm working with before I buy. I've heard the got NP205's and i've heard they got a rockwell unit, anyone know for sure?
Thanks-
Eric
'06 2500 HD 4x4. manual transfer case, crank windows.
'88 V10 Suburban 4x4,"The Pig Rig" L05, 700r4, NP208, 4x4 beater camper fun truck project.
My trucks don't leak oil, they mark their territory.
ericjon262 is offline   Reply With Quote
Old 12-03-2011, 03:19 AM   #2
odog
odog's Avatar
Re: 1967 Tcase
As far as I know the 67s have a rockwell T221.
The Rockwell is a strong gear driven tcase. It howls a little bit due to the cut of the gears, but it is strong. Mine has been running hard since 67 and the collar in the trannt to tcase adapter finally gave out.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 12-03-2011, 03:45 AM   #3
SS Tim
SS Tim's Avatar
Re: 1967 Tcase
Transfer cases were Rockwell T-211s untill early 1969 then the NP205 was used. Also the earlier trucks had closed knuckle, drum brake front ends. If you want disc brakes and big tires you might be better off with a later truck.
SS Tim is offline   Reply With Quote
Old 12-03-2011, 01:31 PM   #4
ericjon262
Re: 1967 Tcase
Thanks, would a 86 3/4 ton front dif be an easy swap then?
Old 12-03-2011, 11:14 PM   #5
SS Tim
SS Tim's Avatar
Re: 1967 Tcase
Not really sure, but I think the '84 down D44 open k/disc axle and the '76 up D60 are pretty much bolt in. Need to do a forum search and read through them for specific axle swap info..
