12-03-2011, 07:56 AM | #1 |
Brake lines. What is wrong with this picture
From inline tube. Does this look right? Should I bend the passenger side line so it fits? This is on a 67 c10. I should have listened and bought else where
12-03-2011, 08:15 AM | #2 |
Re: Brake lines. What is wrong with this picture
Im no help here. Just throwing this out there. The middle one isnt turned backwards is it.
12-03-2011, 08:29 AM | #3 |
67-72 parts collector,…
Bend it.
12-03-2011, 08:37 AM | #4 |
Thanks Keith. You always have the answer. The kit I bought also runs the lines on the outside of the frame. This makes the "T" real close to the A arm.
12-03-2011, 08:44 AM | #5 |
I've found that most of these kits require a little bit of "tweaking".
You should be able to "twist" the right side brake line to make it work. Take your time and don't kink the lines.
12-03-2011, 10:37 AM | #6 |
Keith, thanks for the help. I am taking pictures as I go in case others need to know which line is which. I just held the rear lines up to the rear axle and those need to be bent too.
Wayne |
12-03-2011, 09:12 PM | #7 |
12-03-2011, 09:35 PM | #8 |
I am a Referee of life.
Maybe I'm glad they just dropped my order.I waiited almost 6 months and 3 phone calls before cancelling.Looks like the ones I rebent are closer than that.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
12-03-2011, 09:37 PM | #9 |
Mine came the same way. I altered things to fit, but I'm not too happy with the look. You can kinda see what I did in this picture:
The part I don't like is the line that comes across the cross member, which I don't have a good picture of.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
12-04-2011, 02:02 PM | #10 |
Sierra Grande Club
Inline Tube has the worst costumer service, if you try to inform them that something is wrong they'll just try to blame your truck not being correct.
I had a similar problem with their SS transmission cooler lines. I tried a few other brands but the Inline Tube was the best product quality - just had to make them fit.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
12-04-2011, 03:44 PM | #11 |
I had to twist one of mine 180 degrees. It's like they bent one end and then the other end. With no attention to the clocking of the ends to each other. I had to drive over to a buddies to look at his project truck just to figure out what the problem was.
70 CST Bunch of old Camaros |
12-04-2011, 03:53 PM | #12 |
guess i got lucky for once . my inline tubeing fit no problems anywhere
12-04-2011, 07:43 PM | #13 |
All mine from inline tube fit excellent (Standard Steel Lines) with the exception of the Fuel line from the pump to carb on my 6. Was just the wrong line altogether, But I made my own and was happy never the less
