12-03-2011, 02:38 PM | #1 |
C/10 junkie
Does this look right to you??
Ok so I just installed my ECE rear shock locators and for some reason it appears that the bottom bolt is not in line with the bottom of the shock mount. Nothing appears to be bent or broken so is this normal or do I have a defective bottom bracket? I thought maybe when they welded the bottom together maybe they welded it crooked but it looks straight. Anyone else run into this problem?
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
12-03-2011, 02:48 PM | #2 |
Re: Does this look right to you??
Did you install the upper mounts too? If your using the original shock mounts for the top this can cause it. Also there should be a spacer between the shock and the the shock mount.
Posted via Mobile Device Last edited by mgkgmc; 12-03-2011 at 02:57 PM. |
12-03-2011, 02:48 PM | #3 |
are those new shocks mine had a metal sleeve that goes inside on the shaft everything else looks ok
12-03-2011, 03:50 PM | #4 | |
C/10 junkie
These pics are WITH the metal sleeve inside the rubber bushings. I am just wondering if there should be a metal spacer that goes in between the bottom shock mount and the lower plate.
12-03-2011, 04:15 PM | #5 |
I have the same issue, decided to swap the lowers side to side and move the shocks to the outside of the frame anyway. Be interesting to see who else had/has this problem and the remedy.
12-03-2011, 04:31 PM | #6 |
C/10 junkie
Do you have any pics of that modification.
12-03-2011, 05:39 PM | #7 |
C/10 junkie
Anyone else???
12-03-2011, 06:41 PM | #8 |
No I dont, camera crapped. I just built a mount off the frame similar to some 4X shock mounts and its out side the frame at an angle dont remember the angle maybe 30* forward and the lower brackets just swap side to side and the angle is correct, cant confirm if they clear the bags tho got over an inch and a half clearance so I hope if now back to the drawing board !.
12-03-2011, 06:49 PM | #9 |
definitely not right. I will try to get a better pic in the next couple days
12-03-2011, 07:05 PM | #10 |
watching this
'71 Chevy LWB all OG '86 Chevy LWB all OG It's all a matter of perception |
12-03-2011, 07:48 PM | #11 |
Mine also have a concaved washer on the inside and outside of the shock to keep the bushing for popping out
Posted via Mobile Device |
12-03-2011, 11:14 PM | #12 | |
C/10 junkie
12-03-2011, 11:30 PM | #13 |
call CPP - take a look at the parts in their 5" drop kit - the 2 left most bolts in the second row from the bottom are what ye seek young jedi (I think).
http://www.classicperform.com/Store/...ck/6572RDK.htm |
12-04-2011, 01:49 AM | #14 | |
C/10 junkie
12-04-2011, 01:03 PM | #15 |
Old Skool Club
Stan, and the other guys at ECE, are very helpful if you just ask. They have a toll-free number, so give 'em a call.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
12-04-2011, 06:03 PM | #16 |
Happy to be here
You need the spacer and inner/outer...
12-04-2011, 10:05 PM | #17 |
C10 CLUB Y QUE!
lol problems already
12-04-2011, 10:23 PM | #18 |
I had the same issue, my kit didnt come with any special hardware. only the bolts to mount the upper brackets to the crossmember.
12-04-2011, 10:34 PM | #19 |
67-72 parts collector,…
That looks like a front upper shock bolt.
12-04-2011, 10:39 PM | #20 |
I think the new rear lower shock bolts look more like these,...
12-04-2011, 10:41 PM | #21 |
12-04-2011, 10:42 PM | #22 |
C/10 junkie
That's funny you say that I have several front upper shock bolts kits that are still brand new and I tried to use one but the hole in the bracket was to small. I guess I could drill the hole in the bracket bigger but I just thought that I shouldn't have to do that.
12-04-2011, 10:43 PM | #23 |
C/10 junkie
Haha Gilbert it's all your fault, you lost the hardware. Lol
12-04-2011, 10:44 PM | #24 |
EDIT:
Just re-read your post about lost hardware. This is the old style they use to use,... http://www.speedwaymotors.com/Shock-...DisplayId=5366 Buy the correct hardware from Speedway Motors and be done. Or check out you local auto parts store. I assume you are using drop rear shocks also?
12-04-2011, 10:54 PM | #25 |
C/10 junkie
Hey lolife that kit from speedway motors looks like it might work. I tried using a bolt and a large nut as a spacer in between the shock and the relocators and it helped a little but it still is at a pretty bad angle. I wish I could post pics from my phone. I will post some pics tomorrow when I get to work.
