12-03-2011, 11:08 PM | #1 |
auto to stick
im work on my 82 and i bought a 83 for a new cab. it is a auto and my 82 is a stick i want the stick cause the other truck has no drive train. i want to know how hard is it to do. and what will i have to do.
12-04-2011, 12:29 AM | #2 |
Re: auto to stick
Swap the cab, and then swap the tranny tunnel from the '82 into the '83. The rest is bolt-on. That's all you need to do.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
12-04-2011, 03:33 AM | #3 |
IT Guy/ Father/ Chevy lover
Re: auto to stick
Just cut along the lines on the hump then swap.
been there done that to a truck. Simple as He|| We put some caulk around the groove in the hump too when we swapped over the tunnel. We did that so we wouldn't have any fumes coming into the cab as well as it helps keep things quiet. Just use some self tappers in the original holes and you are golden.
78 Chevy (Pictures) SOLD 79 Chevy LWB (pasture) 83 Chevy LWB (crushed rusted beyond repair) 02 TrailBlazer SOLD 03 VW Passat wagonSOLD 95 extended cab silveradoSOLD (still in family) 05 Crew Cab Silverado 5.3 (The Turd) WTB: 66 El camino Technology Specialist aspiring to be a gear head. |
12-04-2011, 10:50 AM | #4 |
Re: auto to stick
Swap pedal assembly, swap steering column, drill hole for the clutch linkage, swap (modify) gauge cluster to eliminate the auto indicator.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
12-04-2011, 08:07 PM | #5 |
Re: auto to stick
im taking every off the 82 to put on the 83. the cab is better and the frame is straight. plus its a long bed. i was worried about the hump. i didnt know if i had to do a lot of work or not. but ive gotten alot of good info and found out its easier then i thought. the 83 i found out is a auto 4x4 and it has the same hump as the 82. i dont have the truck at my house, it at a friend and ive never look at it. so thank u guy for telling me what i had to do
