Old 12-04-2011, 12:34 AM   #1
robs_c10
robs_c10's Avatar
Drop Spindle Question
This might sound like a stupid question but I am in the process of restoring my 69 C10. It was lowered "the wrong way". The frame was all chopped up in the back and front well.....I fixed the rear suspension with real drop springs and blocks with a real c-notch kit but now i need to work on the front. It looks like it has cut springs, with a bunch of washers spacing out the A-arms. Is there a way I can tell if the spindles are dropped or stock? I want to lower the front at least 4" if not 5" but I want to ensure it handles well. Any recommendations on "front only kits" or what I need to make this happen? Any assistance in this would be appreciated.
robs_c10 is offline   Reply With Quote
Old 12-05-2011, 11:32 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Drop Spindle Question
You need a 3" drop spindle and a 2" spring to make a 5" drop.
Spring only drop should not exceed 3".
You will also need drop shocks.
Post some pics of your suspension.
It's easy to verify drop spindles.
Keith
Convert to disc brakes.
Old 12-06-2011, 01:09 AM   #3
robs_c10
robs_c10's Avatar
Awesome man.. I'll put up a picture when I get back to it. Probably in a day or two. Thanks for the info. It will get me started. I appreciate it.
Old 12-06-2011, 01:31 AM   #4
AustinScott
AustinScott's Avatar
Stock height spindle, notice where the hub mounts, its lower to the ground.
Drop spindle, notice where the hub mounts, its higher from the ground.
Hope this helps
Scott
AustinScott is offline   Reply With Quote
Old 12-06-2011, 08:11 AM   #5
SCOTI
SCOTI's Avatar
No one has asked.... You mention it's a 69, does it still have drum brakes up front?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-06-2011, 11:44 AM   #6
robs_c10
robs_c10's Avatar
No it was converted to disk. Not sure if this matters but its still 6 lug. Thanks for the pictures AustinScott I appreciate it. That makes it easier for me. this is my first build from ground up and I have never realy payed attention to chasis with anything I have done so this is really helpful.
