Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-04-2011, 02:19 AM   #1
stang3191
alright im trying to get into racing i have some questions
i just got a 92 chevy 1500 350 5 speed how to i get traction to the ground as soon as i pop the clutch i just do burnouts all day haha.
do i need traction bars or what?
its probally a stupid question but just wondering.
stang3191 is offline   Reply With Quote
Old 12-04-2011, 02:22 AM   #2
rpmerf
rpmerf's Avatar
Re: alright im trying to get into racing i have some questions
what kinda tires you running?
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 12-04-2011, 02:30 AM   #3
stang3191
there 270/60/15 and the front are 235/60/15
Old 12-04-2011, 10:29 AM   #4
moggey01
Try slicks, and traction bars. Add or move weight to the rear.
moggey01 is offline   Reply With Quote
Old 12-04-2011, 12:52 PM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
Some day stop by a local truck stop and get a front / rear axle weight. Then you'll know why she don't want to hook up. You need to add a 1/2 ton over the rear tires THEN it will hook n a car wash even with $25 PePBoys tires at all 4 corners LOL
Chassis set up for a drag racer is way different than a utility chassis designed to haul 1/2 or 3/4 ton hay. There are a lot of great books on the subject,, Dave Morgans "DOORSLAMMERS" is one of my favorites to explain theory and basic concept.
That said, a 92 with the leaf spring rear suspension will respond well to CalTracks and sticky tires (slicks, DOT street slicks or a true drag radial), a loose front suspension, and like moogy said..... if it doesn't HAVE to be in the front, move it to the rear and bolt it down.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 12-04-2011, 08:19 PM   #6
djracer
djracer's Avatar
Like Marv said sticky tires and cal tracs will help a bunch. http://calvertracing.com/ The manual trans will be the first thing to break when it does hook. I would looks towards a better manual if you are dead set on one or if it were mine I would put an auto in it.
Move the battery to the rear and lose anything you don't have to have up front.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 12-06-2011, 01:15 PM   #7
noonzor
i would highly recomend that book (Dave Morgans "DOORSLAMMERS") for anyone looking at getting into racing. its help me understand and design the suspension on my truck. as well as just explain how centre of gravity, roll, pitch.... etc all come into play in regards to traction and racing. great book!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 12-06-2011, 04:40 PM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
26 x 8.5 x 15 M/T drag and a set of truck rallies .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-06-2011, 09:49 PM   #9
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
I agree^^^^^^
cal tracks are a must for leaf spring application
slicks or a DOT drag radial
Line lock, and the book.
These are Amazon's prices
4 new from $98.76 14 used from $79.44
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 12-06-2011, 10:23 PM   #10
Super73
Super73's Avatar
For startes, don't dump the clutch on the street. Even a well set up chassis can fry tires with a weak motor if you are dumping the clutch. It will go much faster if you slip the clutch.
After that, follow the other advise, tires, caltracs, moving weight, different front/rear springs/shocks.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
