Old 12-04-2011, 01:45 PM   #1
vegas80step
vegas80step's Avatar
Do you lose the ability to close your AC vents with the billet cover?
What's up guys? Do you lose the ability to close/direct the air out of your AC vents if you use a billet cover?
Seen here:
http://www.lmctruck.com/features/cc/ccbdp.htm
If you do, do I need vents at all?
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy?
vegas80step is offline   Reply With Quote
Old 12-04-2011, 03:44 PM   #2
nekkidhillbilly
Re: Do you lose the ability to close your AC vents with the billet cover?
yep
nekkidhillbilly is offline   Reply With Quote
Old 12-04-2011, 05:09 PM   #3
vegas80step
Originally Posted by nekkidhillbilly View Post
yep
thanks, any idea if you need the vents behind or can I just leave them out?
Old 12-05-2011, 12:08 AM   #4
Hazieview
Building Dreams out of Dimes!
You don't have to have the vents at all. They just enable you to direct air flow where u want it.
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 12-05-2011, 01:21 PM   #5
78 Chevyrado
Yep.
78 Chevyrado is offline   Reply With Quote
Old 12-05-2011, 09:42 PM   #6
my4by2
my4by2's Avatar
You could probably just have that area machined out so you could get to the vents I guess... But this is the main reason I am not going with them - I will be having some custom made that leave the vent open - still need them to be functional - plus the ones on the market are so plain & over-used...
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 12-05-2011, 11:54 PM   #7
Hazieview
SB400 350th
Old 12-06-2011, 12:06 AM   #8
flamingbig10
6.0 powered square
flamingbig10's Avatar
I made my own first out of diamond plate aluminum then sheet metal
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
