Old 12-04-2011, 02:01 PM   #1
OldnRusty
Upper Radiator Support?
Hey all, been looking for an upper radiator support. They are hard to come by. I have found some for a 283. I have a 3 core aluminum radiator. Would this fit?
OldnRusty is offline   Reply With Quote
Old 12-04-2011, 08:37 PM   #2
brawley
Easy Does It
brawley's Avatar
Re: Upper Radiator Support?
i dont think they make repo. for the 60-66 trucks but the V8 version is larger, you could try the 67-72 upper radiator bracket
brawley is offline   Reply With Quote
Old 12-04-2011, 09:06 PM   #3
OldnRusty
Thanks for the reply. I went ahead and purchased it. I figure I can modify it if it will not work. It looks like the right fit so I am going to push forward. I wonder why do do not make a reproduction? Brawley thanks again for the reply! Have a great week.
Old 12-05-2011, 11:37 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
Is this the part you're referring to? I fabricated this one from scrap sheet and welded a couple of OE saddles to it according to the upper tank location of my radiator.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-05-2011, 12:03 PM   #5
1963c-10
1963c-10's Avatar
I have a 4 core aluminum and it worked for mine
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-05-2011, 12:04 PM   #6
1963c-10
1963c-10's Avatar
Nice fab work...looks real close to the original
Old 12-05-2011, 12:40 PM   #7
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I think I may have one I wont be using, PM me and Ill get a pic for you.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
