Old 12-04-2011, 05:16 PM   #1
jbclassix
Junk Yartist
jbclassix's Avatar
Rate these door panels
Has anyone used these LMC re-pop door panels? I see they are now offering them in grey, which is what I am interested in. I am looking at the 70-71 panels, but I don't have the wood grain on the rest of the trim, so I am not 100% on that either. Anyone have experience with the LMC panels?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 12-04-2011, 07:14 PM   #2
black_sheep454
Re: Rate these door panels
I put these on the other day from lmc and the only problem I had was that I had to trim about 1/8th of an inch of the top to get them to go up and fit it the recessed part of the door and then had to make the bottom holes a little bigger were the screws go in. The only thing I didn't like about them is that the 4 bottom jokes aren't counter sunk so the screw heads stick out a little.
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 12-04-2011, 08:20 PM   #3
Tim Christian
Tim Christian's Avatar
I would get a pair of orginal metal panels and cover them with PUI orginal style covers the 69 ones don't have woodgrain but does have the scroll and a small Bowtie
Tim Christian is offline   Reply With Quote
Old 12-04-2011, 11:57 PM   #4
jbclassix
Junk Yartist
jbclassix's Avatar
black_sheep454, that is exactly what I wanted to see, that's not what I want my doors to look like. Thank you.
Tim Christian, do you have a link for PUI? My original metal panels are sweet. The PO had them powder coated, so they are worth keeping. I don't want the wood grain, so recovering them would be great.
-Jeremy
Rebuilding an NP205
Old 12-05-2011, 12:36 AM   #5
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Black Sheep, go to your locol hardware and get some trim washers, there counter sunk and will help hold your panels down..also look much better.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 12-05-2011, 12:59 AM   #6
PAWS 72
PAWS 72's Avatar
thats the reason i aint going to go LMC anymore.bad fit parts are junk.i know they are somewhat lower sometimes but i'm tired of getting stuff and still have to make it fit.
i finally figured out that the order takers just answers phone only the dont know jack.
talked to a couple venders on here they know there stuff and will help you. i like that
PAWS 72 is offline   Reply With Quote
Old 12-05-2011, 01:51 AM   #7
domeier
domeier's Avatar
I have the ones on the far left of the brochure. I like 'em.
domeier is offline   Reply With Quote
Old 12-05-2011, 06:41 AM   #8
I would never consider buying fake imitation molded plastic door panels. '72 is the only year for hard molded door panels. The rest get vinyl and nothing else gets it in my book. I rank those panels with Kmart rash or JC Whitney junk. Get the real deal,like Tim Christian suggested.
Old 12-05-2011, 09:05 AM   #9
Tim Christian
http://www.puiinteriors.com/
Old 12-05-2011, 11:44 AM   #10
black_sheep454
I put those on it but the problem is that the door panel curves were the holes are so the bottom side sticks out.
