Carpe manana
![]() ![]() Join Date: Dec 2010
Did GM ever use stainless trim on window sweeps (see pics)?
Just installed all new door weatherstrip on my green K10 (thanks GMC Pauls) with sweeps that have stainless trim (see pic). With an eye now toward the K20 build I'm curious to know if GM ever made sweeps with stainless trim as the NOS set I bought lacks the trim. Both are Cheyennes and the K20 doesn't have sweeps with trim as you can see in the pic but the K10 sweeps had disappeared long ago. No luck on a board search of prior related posts. Thanks, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Re: Did GM ever use stainless trim on window sweeps (see pics)?
My 68' and 70' trucks are originals, they have no chrome strip. My 72' k-20 custom deluxe had them only on the inside anti rattle felt.
Carpe manana
Thanks for the follow-up. Both my Cheyennes have only black metal on the inner felt fuzzies, no stainless and I suspect the fuzzies are original. Puzzling. Anyone else have stainless OEM sweeps or seen NOS sweeps with stainless trim?
#4 | |
Sierra Grande Club
I have new felt to put on, maybe I can contact you for pointers? Dean
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Carpe manana
Absolutely! Send a PM whenever you're ready for the install and thanks for the follow-up. Pete
![]() Join Date: Dec 1999
I say no but on the repops the stainless/chrome bead are the only ones I have found that goes aganist the glass nice like they should the black bead ones are short and don't touch the glass correct or at least when I was selling parts that how they were.
Carpe manana
Good to know. I like the look of the stainless trim. The aftermarket brand I got was "Repop" and I believe they are US made.
I was wonderin about this, too. Mine are all black and probably original. Does anyone know of a vendor that sells decent replacements black only ???
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
